WHERE'S THE OIL COMING FROM?!
Guest
Posts: n/a
i have bad oil leak and ive been trying to find the problem for the past two weeks. im sooo frustrated. ive torn this engine down and put it back together a million times now.
there is oil all over the oil pan so i thought it was the pan gasket. put a brand new one on with hondabond and torqued it to 9 lbs. still leaking. then i notice there is oil everywhere inside the timing belt covers and all over the belt sprokets and cam gear. so i put brand new oem crankshaft seal and camshaft seal on. and its still ******* leaking. its comming out pretty good. but only when i drive it. if i let it sit there and idle for an hour and rev it up, i see nothing leaking.
possibly rear main seal, oil sending unit.also if you didnt put hondabond in proper places on oil pan gasket , could be coming from there
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">possibly rear main seal, oil sending unit.also if you didnt put hondabond in proper places on oil pan gasket , could be coming from there</TD></TR></TABLE>
rear main is on the other side of the engine. but thats brand new also. im a hondabond freak and its everywhere, i know where it goes. oil sending unit not near the timng belt and its not leaking anyways. remember there is oil everywhere inside my timing covers. you know the covers that go over the timing belt and cover it up.
Remove the upper timing cover and take pictures if at all possible. Something may have gone wrong when you installed the cam/crank seals (too far in or damaged them).
Thats really the only thing that could be what leaking unless your headgasket is leaking but thats not really likely.
Pics would help.
Pics would help.
its gotta be the cam seals. did you make sure you put the cam seals on the correct direction?
this happend to two cars that i know of, replaced cam seals, works fine.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">its gotta be the cam seals. did you make sure you put the cam seals on the correct direction?
this happend to two cars that i know of, replaced cam seals, works fine.</TD></TR></TABLE>
r u kidding? how could you put a cam seal (sohc) on backwards? im not that dumb guys..
you can put a cam seal on backward. when looking at the cam seal from the side, it would look like this ] . the open ended part goes facing the motor, the flat part faces the cam gear.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">could be your headgasket, had a bad oil leak, then shortly later blew my d15.</TD></TR></TABLE>
oem headgasket is a couple miles old, also have ARP head studs. i do **** by the book boys.
have ya tried removing the timing cover then running the engine for a while and seeing if it leaks from wherever? also i know theres a dye out there you can buy to put in your oil to determine where the leak is coming from. good luck.
Ser1N
Jan 26, 2020 02:26 PM
Kyle700
Jan 18, 2015 04:57 PM
