'90 CRX w/ a B16A2 just died on me and will not start
Old Sep 3, 2005 | 07:54 AM
Bump's Avatar
Default '90 CRX w/ a B16A2 just died on me and will not start
Last night i was driving down the road, the car was runnin perfect, then out of nowhere the CEL turns on and a split second after that the engine shuts off(no sputter before it shuts off, jus completely shuts off) and i coast to a stop. the b16a2 has been converted to obdI. so right now the car wont start. its not the battery b/c it is trying to turnover, could there be something wrong w/ the fuel pump? or mayb it isnt sparking? i have no idea as of right now so any help would be much appreciated.
Old Sep 3, 2005 | 09:49 AM
Bump's Avatar
Default Re: '90 CRX w/ a B16A2 just died on me and will not start (Bump)
i just found out when i turn the hey in the ignition, not all the way to start it, theres a clicking coming from the solenoid thats attached to the intake manifold and located on the back of the IM(i dunno what its called), its not that air flow sensor, could be something to do w/ the fuel...when sitting in the drivers seat there also clicking coming from the left side of the dash, which makes me think of something to do w/ the fuel
Old Sep 3, 2005 | 10:50 AM
lodo1's Avatar
check your main relay
Old Sep 5, 2005 | 08:33 AM
jdeemseerx's Avatar
take out the spark plug wires and you can either do it right..get a spark plug tester plug it into the wires like a regular spark plug while someone cranks and see if that wire is sparking..or just ground out the wire with a screwdriver..do it for all four starting wit #1 if your gettin spark then i would check for compression..maybe your timing is off also..if all is good you know your problem is fuel
Old Sep 5, 2005 | 08:46 AM
pushinglikekrazy's Avatar
all the clicking your hearing is most likely relays, nothing to worry about. like the last post just start wit spark. then move on to fuel. check to see if you are throwing any codes as well good luck man
Old Sep 5, 2005 | 09:42 AM
NikoZai's Avatar
Default Re: (pushinglikekrazy)
Codes? Your CEL came on, it should have stored a code right then.
Old Sep 5, 2005 | 05:09 PM
b20pimp's Avatar
Default Re: (NikoZai)
sounds like the igniter in the dizzy to me i have done 2 so far on b20/gsr
Old Sep 5, 2005 | 05:36 PM
hizroyalty's Avatar
Default Re: (b20pimp)
yeh mine did the same thing when the dizzy went as well....i would check the spark, and more than likely ull have to get a new one...
Old Sep 19, 2005 | 04:44 PM
phatgt4evr's Avatar
check connections to ecu mayb ecu failed have it chipped they will send u new wire harness for ur c ar with that motor
buugiewuugie
26
Mar 28, 2007 05:44 AM
gospeedgo1
May 31, 2006 11:44 AM
bmg123
Sep 25, 2005 12:33 AM
96-EJ6 B18C
Jan 8, 2005 06:37 PM
Spooled1.6L
Apr 20, 2004 05:49 AM
