can you raise your car?
Old Sep 3, 2005 | 01:10 AM
ekim952522000's Avatar
Default can you raise your car?
Can you raise your car higer than stock with ground controls?
Informationis for RallyX civic
Old Sep 3, 2005 | 08:24 AM
CaliforniaHighwayPatrol's Avatar
yes you can, but I wouldn't
Old Sep 3, 2005 | 11:18 AM
ohjolt2's Avatar
you could also order an inch taller spring if you run out of threads on the sleeve. Tell them your going to rally it and see what they think the best setup is.
Old Sep 3, 2005 | 03:13 PM
Magick211's Avatar
Default Re: (ohjolt2)
If you do raise it you will have positive camber
Old Sep 3, 2005 | 06:58 PM
RACINTWEEK's Avatar
Default Re: (Magick211)
stock hieght is plenty of clearance for rally-X, just use DA teg springs that are a 1" drop so you dont actually lower the car but get stiffer rates
Old Sep 3, 2005 | 08:02 PM
crix351c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">If you do raise it you will have positive camber</TD></TR></TABLE>
if you lower you will have negqatice camber.....whats ur fckn point
Old Sep 3, 2005 | 08:13 PM
Magick211's Avatar
Default Re: (crix351c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix351c &raquo;</TD></TR><TR><TD CLASS="quote">if you lower you will have negqatice camber.....whats ur fckn point</TD></TR></TABLE>
Get your smart *** comment out of here newb. My point is exactly as stated.
If you raise the car you will have positive camber.
And you are correct if you lower the car you will have negative camber. But most people that care about tires and traction will fix that problem with a camber kit
Old Sep 3, 2005 | 09:14 PM
could a camber kit be used to correct positive camber? In a lifted civic I'm only talking about raising it about 1"
Old Sep 3, 2005 | 09:19 PM
UsDm_Junky's Avatar
once you do it post pics id like to see it, btw what else are you doing to prep your hatchy for rally?
Old Sep 3, 2005 | 09:28 PM
b18-c-rx's Avatar
Default Re: (ekim952522000)
yeah, some camber kits can correct from +1 deg. to -1 deg, and some are just for correcting things like -3 deg (large drops). Just check the specs of the camber kit you want to buy and make sure it cna handle it. lots of camber kit dealers have info that shows for what drop (or raise, i guess) their product works if you are not sure how many degrees off you will be.
Old Sep 3, 2005 | 10:13 PM
Jesterian's Avatar
24.243.141.75
Default Re: (b18-c-rx)
I was thinking about doing this too. I deliver pizzas and hit some nasty roads sometimes, it'd be nice to have a couple extra inches ground clearance. Plus, it'd look unique.
Old Sep 4, 2005 | 01:38 AM
Default Re: (UsDm_Junky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UsDm_Junky &raquo;</TD></TR><TR><TD CLASS="quote">once you do it post pics id like to see it, btw what else are you doing to prep your hatchy for rally?</TD></TR></TABLE>
autopower roll bar
b16 swap with lsd
disc brake conversion
kumho rally tires
roof vent
skid plates
sparco speed seats
strut bars
that the basics of it
Old Sep 4, 2005 | 07:55 AM
RACINTWEEK's Avatar
the roof vent is a little extravagent for rally-x. just remember, Don't use a front sway bar and set your rear susp as stiff as possible
Old Sep 4, 2005 | 12:45 PM
RaysBoomBoomLude's Avatar
Default Re: (RACINTWEEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACINTWEEK &raquo;</TD></TR><TR><TD CLASS="quote">the roof vent is a little extravagent for rally-x. just remember, Don't use a front sway bar and set your rear susp as stiff as possible</TD></TR></TABLE>
Why not use a front sway bar??
Old Sep 4, 2005 | 12:54 PM
TheSSG's Avatar
Default Re: (LaFawnduh)
I'd assume to let you slide around turns better...
Old Sep 4, 2005 | 01:19 PM
Default Re: (TheSSG)
it's only going to be used for rally across for about another six months until I get the kinks worked out then I'm going to move to stage rally's
Old Sep 4, 2005 | 01:42 PM
RACINTWEEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh &raquo;</TD></TR><TR><TD CLASS="quote">
Why not use a front sway bar??</TD></TR></TABLE>
it will cause major understeer on dirt and gravel. if your right tire is on a large bump the sway bar will start to lift the left wheel and you loose traction.
Stevis42589
Oct 15, 2007 08:01 PM
parki59
Apr 25, 2006 03:37 PM
zacatkings
Suspension & Brakes
Mar 4, 2006 05:56 PM
boostin1cam
Jan 23, 2005 09:17 AM
Motorgroove
Aug 10, 2004 08:40 AM
