Need torque specs for the b17 and b18??????
Kids, I lost my Helms and dont want to buy a new one. If someone would fill in the blanks, I will return to the helper. . . . .A sexual favor jk
Rod bolts
cam caps
head bolts
Also a photocopy of the piston ring alignment would be cool.
I know that no rings align the pin, the #1 and #2 rings are 90 degrees apart and the oil rings are opposite #1 ring at 15 degree intervals.
ANYONE KNOW THIS IS CORRECT??
THANKS GUYS
Rod bolts
cam caps
head bolts
THANKS GUYS
thanks be to you both, I know/knew the sequence, just not the tightness.
Since this post, I dipped the block and head, reassembled and painted the fresh aluminum w/my special glow in the dark violet paint. Dries clear, but glows in the dark. Pics to you both later.
xXx Justin xXx
Apr 1, 2004 07:20 PM
