What kind of aftermarket tubular upper control arms are these?
Old Sep 2, 2005 | 03:25 PM
DelSolDon's Avatar
Default What kind of aftermarket tubular upper control arms are these?
I need to replace the balljoints on these upper control arms, but they are welded to the adjuster plate. I am thinking that if I find out what kind of control arm these are, then I can get an entire new adjustment plate with balljoint. Does anybody know what kind these are?
*click on thumbs below for larger pic*
the joints don't seem to be too bad, the boots are just ripped to hell. can i just replace the boots? if so, is that a honda OEM part?
Old Sep 2, 2005 | 03:29 PM
RaysBoomBoomLude's Avatar
Default Re: What kind of aftermarket tubular upper control arms are these? (DelSolDon)
have you tryed Grinding off the welds?
what car are these out of? Im assuming EF, but who knows.
Old Sep 2, 2005 | 03:36 PM
DelSolDon's Avatar
Default Re: What kind of aftermarket tubular upper control arms are these? (LaFawnduh)
yea, they were on a 90 hatch SI, but it has larger (assuming integra) than stock civic OEM rotors/calipers up front. so, i guess it could be a DA suspension. it does have rear discs also which leads me to believe the entire setup is from an integra. also the inner fender well has been "modified" for the control arm to clear. i thought about grinding the welds off, but it would be easier to either replace the whole adjustment plate or just the balljoint boot if i can do so.
Old Sep 2, 2005 | 03:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">yea, they were on a 90 hatch SI, but it has larger (assuming integra) than stock civic OEM rotors/calipers up front. so, i guess it could be a DA suspension. it does have rear discs also which leads me to believe the entire setup is from an integra. also the inner fender well has been "modified" for the control arm to clear. i thought about grinding the welds off, but it would be easier to either replace the whole adjustment plate or just the balljoint boot if i can do so.</TD></TR></TABLE>
yah, Ive never herd of replacing a balljoint boot. hmmm I have no idea what those are from. or who makes them. I would guess if you get the messure ments of the adjuster plates, and e-mail the people who make those, the specs, and sure you can find one that fits.
but there was a reason why the adjuster plate was welded. it was sliping. It might not be even worth all the trouble?
Old Sep 2, 2005 | 03:54 PM
DelSolDon's Avatar
i think you misunderstood, the balljoint is the only thing welded. it is welded between the top rim of the balljoint and the adjuster plate to hold the balljoint in.
Old Sep 2, 2005 | 04:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">i think you misunderstood, the balljoint is the only thing welded. it is welded between the top rim of the balljoint and the adjuster plate to hold the balljoint in.</TD></TR></TABLE>
OHHHHHHHHHHHHHHH well ****, grind it off and get a new ball joint????
though I didnt know you can push in and out Upper Ball joints.
Old Sep 2, 2005 | 04:53 PM
Skunk.Werks's Avatar
cut the welds and air hammer it out, easy peasy
Old Sep 2, 2005 | 07:48 PM
Crx Jimmy's Avatar
they are this brand http://www.truckn-store.com/pr...89860
they are notorious for not fitting right, the pics are yellow but they are actually blue like yours
Old Sep 2, 2005 | 07:50 PM
Crx Jimmy's Avatar
Default Re: What kind of aftermarket tubular upper control arms are these? (Crx Jimmy)
oh yeah- stock balljoints go in them, they were welded to yours for some unknown reason? just grind off and put new ones in or just buy a new boot from honda
Old Sep 2, 2005 | 07:55 PM
DelSolDon's Avatar
sweet, good find. so, are these crap, or what? should i replace the boot, or try to find some OEM control arms? i'm not gonna have the car too low, but it will be lowered a little.
Old Sep 2, 2005 | 08:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">sweet, good find. so, are these crap, or what? should i replace the boot, or try to find some OEM control arms? i'm not gonna have the car too low, but it will be lowered a little.</TD></TR></TABLE>
OEM control arms, Get them from the junkyard, pick and pull, they shouldnt be more then 20 dollers for 2.
Are you really hard up for cash?
Old Sep 2, 2005 | 08:07 PM
DelSolDon's Avatar
no, not hard up for cash, just would rather spend the money on my motor and turbo build than control arms. i just don't want some crap aftermarket control arm snapping while i'm driving around. they don't seem to be too horrible though. nice heavy feel, nice welds between the tube and the flat plate. however the OEM piece is all one cast piece which seems to be stronger and less worries for me.
Old Sep 2, 2005 | 08:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">no, not hard up for cash, just would rather spend the money on my motor and turbo build than control arms. i just don't want some crap aftermarket control arm snapping while i'm driving around. they don't seem to be too horrible though. nice heavy feel, nice welds between the tube and the flat plate. however the OEM piece is all one cast piece which seems to be stronger and less worries for me.</TD></TR></TABLE>
yah, ide have to agree. Go to the pick and pull, cheap as hell. Expecialy if you can pull it out your self.
static-x
Suspension & Brakes
May 30, 2014 05:27 PM
Hedi422
May 14, 2008 05:16 AM
CRX_Fenatic
Oct 22, 2006 07:24 PM
DelSolDon
Suspension & Brakes
Sep 3, 2005 11:38 AM
donesixer
Jan 23, 2003 01:02 PM
