Shifting to park in a moving vehicle. (Roll Shifting)
Old Sep 2, 2005 | 01:19 PM
mjeet's Avatar
Default Shifting to park in a moving vehicle. (Roll Shifting)
Hi,
The car was moving at about 5 MPH and I accidently hit the gear stick (automatic transmission) and shifted it to Park. I heard some grinding sounds and I immediately hit the brakes. I thought I had burnt the transmission but the car is running fine. What are the things I should check for that might have gone wrong and possibly show up later. I am willing to repair them now instead of paying a bigger price later on.
Old Sep 2, 2005 | 01:29 PM
fw190bvi's Avatar
Default Re: Shifting to park in a moving vehicle. (mjeet)
um...maybe drain the fluid...look for any metal scrapings
Old Sep 2, 2005 | 01:33 PM
mjeet's Avatar
Default Re: Shifting to park in a moving vehicle. (fw190bvi)
you mean a transmission fluid change.. i just had one not even a month ago.
Old Sep 2, 2005 | 01:55 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjeet &raquo;</TD></TR><TR><TD CLASS="quote">you mean a transmission fluid change.. i just had one not even a month ago.</TD></TR></TABLE>
well, if that was before you had you "accident" it doesnt matter...
the idea is to drain it, and then look for metal flakes. lots of metal meant that the gearing grinded up itself, and you might have a catastrophic failure in the near future
Old Sep 2, 2005 | 02:18 PM
accrd18's Avatar
how do u accidently move it into park..i got an auto and the only way mine goes into park is if i have my foot on the brake..newer cars dont let u until the speed sensor sees 0
Old Sep 2, 2005 | 02:59 PM
HondaTechPro's Avatar
The noise you heard is called the Park pawl. Basically it is just a toothed wheel that a rod engages.... when the rod is engaged, it can't turn or roll away. Think of it like a fan you might have in your window. If the fan blade is stopped... you can jam something between the blades and keep it from turning. If you try to jam something in before the fan stops turning, it will make a very similar noise to what you heard. I think draining the trans fluid and refilling it is a good idea, but I highly doubt you did any significant damage... your trans will be fine.
Old Sep 2, 2005 | 07:56 PM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">um...maybe drain the fluid...look for any metal scrapings</TD></TR></TABLE>
When you drain it you may want to get a funnel or better a screen to place under drain plug so you can separate any particles from the fluid to better visually inspect. Also you can check your magnet on the drain plug for stuff.
Ouch
Old Sep 2, 2005 | 11:25 PM
shadow_ridge's Avatar
Default Re: Shifting to park in a moving vehicle. (sauceja)
that happend to me once coming home going in side my parking space, everything seems to be fine tho..
what happend to me.. when i bought the car almost 3 years ago the auto gear box was lose as anything thing else. i was getting ready to drive in and my hand was on the **** and slightly breaked, then bam i was in park and it made that nose..
it happends.. but im the gears are fine tho
Old Sep 5, 2005 | 08:10 AM
accrd18's Avatar
Default Re: Shifting to park in a moving vehicle. (shadow_ridge)
i guess that 0 speed thing was out of the ? then..hmmm dont some automatic cars have that feature tho?
Old Sep 5, 2005 | 08:51 AM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: Shifting to park in a moving vehicle. (drivinaway367)
Only time I've "accidently" put an auto car in park was one owned by Avis, I was going about 40 mph at the time Car still drove fine after that, so if a pos Ford can take it, an Accord can take it at 5mph
Old Sep 5, 2005 | 09:31 AM
P_Adams's Avatar
Hondatechpro is correct.
Although I've seen one catastrophic failure from this with a TH200 (GM Turbo-Hydramatic 200), (cracked the case), It sounds like you dodged the bullet.
A clue would have been chunks of aluminum and pieces parts on the ground and a big F...in' puddle under the car.
P
Old Sep 5, 2005 | 07:01 PM
HondaAccordTdR's Avatar
Default Re: Shifting to park in a moving vehicle. (P_Adams)
I did that once with my moms old toyota, except it was just like the ebrake was pulled car stopped.... good luck.
creator1322
Sep 27, 2008 04:52 PM
jaysome01
Sep 19, 2008 11:53 AM
Aralliius
Aug 13, 2007 07:26 PM
py389itr
Feb 28, 2007 04:41 PM
TopNotchR
Sep 24, 2004 06:50 PM
