car doesn't want to start
Old Sep 2, 2005 | 07:02 AM
89txrex's Avatar
Default car doesn't want to start
i have a 89 crx dx and my problem is my car will start up in the mornings just fine, but later as the day goes on and it gets hotter the fuel pump will not turn on. i have to keep turning the key back and forth, then finally it will "catch" and the pump will come on. any ideas as to what might be the problem? could it be a relay? please help, it is getting really annoying
Old Sep 2, 2005 | 07:23 AM
redryder's Avatar
Default Re: car doesn't want to start (89txrex)
thall huh, i'm from austin so i'll help ya. change the main relay. It happens all the time. I'ts on the drivers side Inside the car next to the main fuse box, to the left. . it says main relay and some other stuff. You have get under there to look though. I wish I could post a picture up here but I cant. dont know how.
Old Sep 2, 2005 | 10:27 AM
89txrex's Avatar
cool, thanks fir the info
Old Sep 2, 2005 | 10:35 AM
rolledthatho's Avatar
yeah you have a bad main relay
Old Sep 2, 2005 | 10:45 AM
Suck my DX's Avatar
Default Re: (rolledthatho)
WHY WOULD U NEED SOMEONE ELSES HELP TO CHANGE THE RELAY...IT TAKES LIKE 5 SECONDS....
YEAH I KNOW IM POSTIN IN ALL CAPS BUT IM TOO LAZY TO REWRITE..
Old Sep 2, 2005 | 10:51 AM
89txrex's Avatar
i don't need help changing the relay, i can do that myself. i needed help figuring out if that is what it was, did you not understand the post or what?
Old Sep 2, 2005 | 10:58 AM
Suck my DX's Avatar
Default Re: (89txrex)
they already told u its the main relay..if u have an ef they are bound to go bad eventually...so change it...did u not understand that or what?
Old Sep 2, 2005 | 11:03 AM
89txrex's Avatar
chill out bro, i did understand what they told me. i was just being sarcastic.
Old Sep 2, 2005 | 01:29 PM
teewhy55's Avatar
its right above the hood lever under the steering wheel. i'd maybe see if you can run some solder in there to clean things up
Old Sep 2, 2005 | 01:44 PM
Suck my DX's Avatar
Default Re: (teewhy55)
yup a faulty connection will definitely cause the relay to malfunction...look if u can find any broken or open connections and fix if possible...if not then u need a new one <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89txrex &raquo;</TD></TR><TR><TD CLASS="quote">chill out bro, i did understand what they told me. i was just being sarcastic. </TD></TR></TABLE>that was not sarcasm it was beinadickism...im not here to give anyone a hard time im here to learn and teach man...the whole point of this forum is to help out fellow honda owners
Brand
21
Sep 8, 2022 09:39 AM
ckirso
Mar 18, 2013 08:08 AM
KDvtec5757
Sep 17, 2008 09:08 PM
confucioussae
Sep 19, 2006 08:05 PM
