Compression Check After rebuild
Old Sep 1, 2005 | 10:11 PM
USDM EG's Avatar
Default Compression Check After rebuild
I just got 1000 miles on my motor after a rebuild (New rings, spoon head gasket, and new connecting rod bearings) (97 spec ITR) I had around 130 on all 4 cylinders when i first started it up, that seems extremely low to me. When we honed the cylinders, we used 220 grit, instead of 400, we didnt realize what we did until we were done. Also when i do the check, i have the other 3 spark plus in, does taht make a differnece?
Im gonna recheck the compression 2morrow
BTW: its a B Series ITR swap. stock internals except spoon head gasket.
Also ive seen stock itrs get 200-210 on a compression check
Modified by USDM EG at 9:12 AM 9/2/2005
Old Sep 2, 2005 | 01:32 AM
gsrious's Avatar
130 hella low... im assuming you have a b series vtec motor(since you said you have something of itr spec)
i was thinking you should be around the 200's.
what type of cams do you have in the motor?
Old Sep 2, 2005 | 06:11 AM
USDM EG's Avatar
Default Re: (gsrious)
the whole motor is stock except a spoon head gasket and yes its a b series ITR swap.
i did a wet test and i got cylinder 1 to 200, so im assuming taht means my rings arnt broken in yet...
Old Sep 2, 2005 | 07:50 AM
mmuller's Avatar
Mad Scientist
Default Re: (USDM EG)
so after 1k miles your getting 130 psi?
If so your rings are not going to seat anymore.
Thats a big difference on honing stones mister....
Old Sep 2, 2005 | 07:59 AM
USDM EG's Avatar
Default Re: (mmuller)
i had a feeling taht was going to happen.....
time for another rebuild i guess
anyone else have any ideas?
Old Sep 2, 2005 | 11:41 AM
95lstegman's Avatar
yeah, so you just honed 220 grit and then reused stock pistons? i'm wondering if at that grit level you might take off enough material to actually oversize the bores enough to change piston-to-wall clearance. pull that sucker apart and use your micrometers mister!
Old Sep 3, 2005 | 08:30 PM
USDM EG's Avatar
Default Re: (95lstegman)
well good news, i did a compression check, and now they are at 200!!!! im excited,
Old Mar 2, 2006 | 01:53 AM
USDM EG's Avatar
btw, after a long update and 3 months in storage, all 4 are at 245 psi!
Old Mar 22, 2006 | 01:45 AM
Circuit Star-29's Avatar
Why is this? Thats really odd...
Old Mar 22, 2006 | 02:22 PM
wildoutwhitegsr's Avatar
So basically what happened is because you used too coarse of a grit when honing it took that much longer for your rings to seat properly?
Old Mar 22, 2006 | 07:03 PM
Default Re: (wildoutwhitegsr)
Or it ate the rings and the piston...prolly the rings though
tunedek
Jul 20, 2004 05:15 PM
Slammd Sol
Dec 28, 2003 06:56 PM
JDMvtecDRAGSTA
Mar 26, 2002 01:55 PM
FSTASNTZ
Aug 25, 2001 04:08 PM
