05 RSX Types S
uhhh...**** your warranty?? You dont **** ur warranty if u over rev...thats why there is a rev limiter. Now if you use krpo u can raise ur rev limit to 8600 which is perfectly safe because the k20a2 use s2000 valve train so it can easily handle 9k rev. but how would the warranty know u revved to high??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jsin »</TD></TR><TR><TD CLASS="quote">8600 which is perfectly safe because the k20a2 use s2000 valve train so it can easily handle 9k rev.</TD></TR></TABLE>
HAHAHA
HAHAHA
Guys they put the redline where it is for a reason....
Maybe thats why the new s2000's dont have a 9k red line anymore.
I just assume that if you want to rev your car higher like using kpro then build your engine to handle it, like toda mods. Its what im going to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiPBoi »</TD></TR><TR><TD CLASS="quote">ur ecu throws out codes everytime u reach the rev limiter..even wen u get to high revs...so if they use a code reader it would show that u reved high...</TD></TR></TABLE>
i dont know about that. ive used my buddies code reader to clear the cel from my dcrh and that was the only code that popped up. ive hit rev limiter numerous times in my car...(i know its not anything to be proud of) and i havent gotten a code yet for it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TemperdSoul »</TD></TR><TR><TD CLASS="quote">Guys they put the redline where it is for a reason....
I just assume that if you want to rev your car higher like using kpro then build your engine to handle it, like toda mods. Its what im going to do. </TD></TR></TABLE>
the ap2's have a 2.2 liter now that is why the redline as at 8000. the k20 is a 2 liter engine. the f20c is a 2 liter engine.
to reset the codes thrown, just pull the battery out.
it's up to you if you want to rev that high. 1.6's can hit 10k rpm's, but it is .4 liters smaller than the k20.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReV LiMiT »</TD></TR><TR><TD CLASS="quote">
i dont know about that. ive used my buddies code reader to clear the cel from my dcrh and that was the only code that popped up. ive hit rev limiter numerous times in my car...(i know its not anything to be proud of) and i havent gotten a code yet for it....</TD></TR></TABLE>
maybe its different for our car then. my friends integ threw a cel so we checked it and it came up wit a **** load of high rev codes...and it turned out he needed to buy a new gas cap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiPBoi »</TD></TR><TR><TD CLASS="quote">maybe its different for our car then. my friends integ threw a cel so we checked it and it came up wit a **** load of high rev codes...and it turned out he needed to buy a new gas cap...</TD></TR></TABLE>
roflhouse, ah ahah ha
