stock rod bolts and nut issue ?? help needed
Old Sep 1, 2005 | 04:17 PM
The Stance's Avatar
Default stock rod bolts and nut issue ?? help needed
i find that i can thread the nuts on easily with no resistance ....to my understanding should these not be luck nuts ??? which should lock ??? well they dont seem to lock so im a bit worried about torqueing them down....or was i supposed to replace these during my build up ??? i started out with a motor that had less then 50,000km should these be shot already ?? or are they 1 time use only ??
Old Sep 1, 2005 | 04:22 PM
Yambor's Avatar
Default Re: stock rod bolts and nut issue ?? help needed (The Stance)
they are just nuts, they thread on and torque down..
Old Sep 1, 2005 | 04:24 PM
The Stance's Avatar
are you sure ??? what keeps them from un torquing and coming off ??? i would think they would at least be locking nuts....
Old Sep 1, 2005 | 06:51 PM
Sam92Teg's Avatar
Default Re: (The Stance)
One would think that, but it just isn't the case. If you are that worried, pull your rods out and have ARP rod bolts ($30) installed and the rod resized at a machine shop. The nuts are bigger with the ARP's, but still are not locking nuts.
Old Sep 2, 2005 | 12:26 AM
The Stance's Avatar
generaly how much does it cost to have the rods resiezed for the new arp hardware ??
Old Sep 2, 2005 | 05:19 PM
The Stance's Avatar
BUMP!!!!!
are the nuts supposed to be locking nuts ???
Old Sep 2, 2005 | 05:28 PM
NJIN BUILDR's Avatar
Its because they have been torqued that they don't fall off.Properly torqued bolts stretch slightly and hold a load against the nut.Locknuts just ruin the treads.
Glenn
Modified by NJIN BUILDR at 10:58 PM 9/2/2005
Old Sep 2, 2005 | 06:42 PM
topspeed86's Avatar
Put some loc-tite on the nuts.
Old Sep 2, 2005 | 07:32 PM
The Stance's Avatar
anyone else ever use lock tite to hold rod nuts onto the threads ??
Old Sep 2, 2005 | 08:09 PM
fmrprojects's Avatar
since u have it out upgrade to arp rod bolts. rev to 8500 safely
Old Sep 2, 2005 | 11:12 PM
The Stance's Avatar
well i wont be reving to 8500rpm since i dont have the valve train for it........alose they are not out they are in the block with p30's
Old Sep 3, 2005 | 09:35 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: stock rod bolts and nut issue ?? help needed (topspeed86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 &raquo;</TD></TR><TR><TD CLASS="quote">Put some loc-tite on the nuts.</TD></TR></TABLE>
Do not ever use locktite, torque the bolts to factory spec and be done with it.
Old Sep 3, 2005 | 11:45 AM
The Stance's Avatar
so for the last time just to be sure.......the nuts are not supposed to be locking nuts and the torque will hold these in place and not come lose........
Old Sep 3, 2005 | 03:39 PM
The Stance's Avatar
BUMP!!!!
turboman2.2
Apr 4, 2010 05:05 AM
LSVtechnologytur...
Jul 14, 2008 07:39 AM
milano2kdc2
Aug 13, 2006 05:47 PM
michael O
Jan 6, 2004 08:57 PM
b16supertuner
Dec 15, 2003 05:21 AM
