wtf my VTEC!!!!
Old Sep 1, 2005 | 04:05 PM
neophyte210's Avatar
Default wtf my VTEC!!!!
yo guys i have a 93 honda civic hatch .. its a cx and i have a b16a.... well i used a p05 ecu so i could break in the mota.... but when my p28 came in i plugged it in and it didn't hit vtec ..... my friend just got his swap from hmotors and i used his p30 and it still didn't work.... the thing is when i had the p05 my check engine light wasent on ... but with the p28 and the p30 my check engine light is on .... WTF!!!!!!!
Old Sep 1, 2005 | 06:03 PM
B18C_DD's Avatar
Default Re: wtf my VTEC!!!! (neophyte210)
check the CEL
u might answer your own question if you find out what it's throwing.
Alot of things must be perfect in order for vtec to engage, so just check everything out.
Old Sep 1, 2005 | 07:28 PM
Default Re: wtf my VTEC!!!! (B18CDD)
anybody else got any hints... my check engine will stop vtec???
Old Sep 1, 2005 | 07:55 PM
asubennett's Avatar
Check all of your wiring first. There is a great link stickied in the EG forum that shows what every pinout is for on a P28 and what wires are what coming out of your harness.
Then check your oil level and then check your oil pressure.
More than likely you have a wiring issue somewhere.
Old Sep 1, 2005 | 07:59 PM
boosted k20's Avatar
Default Re: wtf my VTEC!!!! (asubennett)
just check to see what code u r throwing and u will solve ur problem!
Old Sep 1, 2005 | 08:56 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neophyte210 &raquo;</TD></TR><TR><TD CLASS="quote">anybody else got any hints... my check engine will stop vtec??? </TD></TR></TABLE>
yes, MIL=engine runs in safe mode meanig no vtec..check your cel fix the problem, and you'll have your precious vtec..
Old Sep 1, 2005 | 10:45 PM
RedHB..D15B's Avatar
Default Re: wtf my VTEC!!!! (onepoint6i)
^Ignorance ownes you!
Old Sep 2, 2005 | 12:05 AM
GetawayInMoscow's Avatar
Default Re: wtf my VTEC!!!! (RedHB..D15B)
did you even wire vtec?
Old Sep 2, 2005 | 11:08 PM
Default Re: wtf my VTEC!!!! (GetawayInMoscow)
vtec is wired but im not sure if it is correctly .... can anyone help me???
Old Sep 3, 2005 | 01:20 AM
fmrprojects's Avatar
go to hybrid garage it shoes you exactly what you should wire for vtec for your particular swap. and check to see if your solenoid is still good
Old Sep 3, 2005 | 09:14 AM
BDBGoalie1982's Avatar
Default Re: wtf my VTEC!!!! (fmrprojects)
Jump the connector, and tell us what code it's throwing
Old Sep 3, 2005 | 07:28 PM
UNKNOWN_MEMBER's Avatar
negative, you can still hit vtec with CEL on. as for the poster, check what code you're throwing, duh?
Old Sep 3, 2005 | 10:19 PM
SPOON_FED_DC_2's Avatar
Default Re: (UNKNOWN_MEMBER)
you cant hit vtec with cel if ur throwing code 21 or 22.
Old Sep 3, 2005 | 10:46 PM
Default Re: (SPOON_FED_DC_2)
guys i took my glove box off and everything and i cant find this plug that im suppose to jump ..... wtf .... i will have a pic of what i got goin on like tomm
Old Sep 4, 2005 | 02:35 AM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CDD &raquo;</TD></TR><TR><TD CLASS="quote">check the CEL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedHB..D15B &raquo;</TD></TR><TR><TD CLASS="quote"> ^Ignorance ownes you! </TD></TR></TABLE>
LEARN HOW TO READ A GOD DAMN ECU FUCKTARD!? JESUS , how much more can these people ******* "help" you!?
Old Sep 4, 2005 | 09:09 AM
Default Re: wtf my VTEC!!!! (clean rice)
so i dont know how to read an ecu ... and i cant find the freakin plug to jump so dont be an *** about it
Old Sep 4, 2005 | 10:03 AM
anyway i finally figureed out what codes im shooting... my car has been rewired by the ecu and all the wires colors are different .... im gettin code 22,41,19 .... but i dont understand why im gettin 19 in a 5spd car... i am using my friends p30ecu that he got from hmotors with his swap.... otherwise its the vtec pressure valve,, primary o2 and automatic transmisson lockup .. wtf .... on my car my pressure sensor is broken off how can i bypass this... someone told me to ground it .. is that right??
Old Sep 4, 2005 | 10:53 PM
anybody i could use some help i would love to hit some of that b-series vtec
EGThang
18
Jun 6, 2008 03:26 PM
slowassciv33
Jun 27, 2007 08:05 AM
neophyte210
Sep 5, 2005 03:12 PM
cioli
Jul 6, 2005 03:05 AM
folta2169
Apr 29, 2005 11:06 PM
