CRX won't start sometimes or suddenly dies
Old Sep 1, 2005 | 01:31 PM
bmg123's Avatar
Default CRX won't start sometimes or suddenly dies
I recently picked up 88 CRX Si with the stock engine.
I wouldn't start at all, so I replaced the cap, rotor, spark plugs, plug wires, and coil. Now it usually starts, but sometimes it won't start or suddenly dies.
When I try starting the car, I can hear the starter running, so I think it must be electrical.
What else could it be? Bad distributor?
Old Sep 3, 2005 | 05:09 PM
darkjedi022's Avatar
Default Re: CRX won't start sometimes or suddenly dies (bmg123)
i have the same problem ..i keep replacing the ingition coil...and works for a little while then samr problem...from what the mechanic told me after i said ill fix it myself...he said the main seals leak oil into the housing of the distrubutor..also my ignitor was bad.... so im just gonna try to fix the ignitor first then go from there.... and see what happens..he wanted to cahrge 583 to repalce that ..fuel filter...air and oil....i said forget it .... if that is hte case i migth as well save money and get a new motor.....
Old Sep 3, 2005 | 05:28 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: CRX won't start sometimes or suddenly dies (darkjedi022)
search into main relay. EF's are known for main relays going out
turn the key on and lisson for the fuel pump to come on. or the CEL to stay lit after 2 secs. if no fuel pump or >2sec CEL then it's the mainrelay
Old Sep 4, 2005 | 09:08 AM
subydoored's Avatar
Default Re: CRX won't start sometimes or suddenly dies (DieMaster)
i had same problem its a short in the module in the dizzy.
Old Sep 11, 2005 | 06:28 AM
Default Re: CRX won't start sometimes or suddenly dies (subydoored)
wait..retype that again ..or explain it .. what is wrong with it ... you sure its not the distrubutor ???
Old Sep 11, 2005 | 07:50 AM
chickenandpickles's Avatar
i had that problem...it was the lttle metal points in the distributor cap...they just got covered in dusty crap
Old Sep 25, 2005 | 12:33 AM
bmg123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">search into main relay. EF's are known for main relays going out
turn the key on and lisson for the fuel pump to come on. or the CEL to stay lit after 2 secs. if no fuel pump or &gt;2sec CEL then it's the mainrelay </TD></TR></TABLE>
you were right, it was the main relay
ryanseverson
Apr 11, 2010 07:00 PM
higgunscrx
Mar 12, 2009 07:50 PM
themex77
Feb 16, 2007 08:58 AM
boostedpleasure
13
Oct 12, 2006 09:10 AM
vtecn8ive
21
Nov 5, 2005 09:35 AM
