quick newb question on turbo timer
Do the wires that go to the ignition on a turbo timer go the the main harness on the ignition or does it involve anything with connecting to the ecu. Any threads on turbo timer installs would be great. Thanks
No there should be no wires to the ECU, all connections should be to the ign. harness, unless there are safety shut down wires, [hood pin, tach. for over rev shut down]
94
94
there is a rpm switch which it says needs to be 5v is needed. Were would i find this 5v rpm signal in a honda crx? Where does the speed sensor wire go to,the safety circuit wire go to also the rpm signal wire go to. Thanks
B18c1turboedEK
Aug 11, 2003 10:18 AM
_Endless_
Jan 5, 2003 09:50 PM
Smashback
Apr 11, 2002 11:44 PM
