quick newb question on turbo timer
Old Sep 1, 2005 | 10:35 AM
cmyrex's Avatar
Default quick newb question on turbo timer
Do the wires that go to the ignition on a turbo timer go the the main harness on the ignition or does it involve anything with connecting to the ecu. Any threads on turbo timer installs would be great. Thanks
Old Sep 1, 2005 | 10:49 AM
fcm's Avatar
fcm
Old Fart
Default Re: quick newb question on turbo timer (cmyrex)
No there should be no wires to the ECU, all connections should be to the ign. harness, unless there are safety shut down wires, [hood pin, tach. for over rev shut down] 94
Old Sep 1, 2005 | 11:11 AM
cmyrex's Avatar
Default Re: quick newb question on turbo timer (fcm)
there is a rpm switch which it says needs to be 5v is needed. Were would i find this 5v rpm signal in a honda crx? Where does the speed sensor wire go to,the safety circuit wire go to also the rpm signal wire go to. Thanks
1baddturbosi
Jan 27, 2007 07:04 AM
B18c1turboedEK
Aug 11, 2003 10:18 AM
_Endless_
Jan 5, 2003 09:50 PM
Lenthrax
Jul 14, 2002 02:33 PM
Smashback
Apr 11, 2002 11:44 PM
