Modify B16B Issue
Old Sep 1, 2005 | 07:37 AM
hybrid69's Avatar
Default Modify B16B Issue
Hi,
i have a b16b with 12:5.1 Comps, Arias forged pistons and fuell head work (Skunk2 Stage 2 Cams, Skunk2 Ret/Springs, Aem Adj Sprokets, Ferrea Valves, P&P Etc) Last dyno tuned 180 Whp / 130 Trq.
i wanted to know if upgrading my injectors from the 290 to 310, could help my high end power.
So far Best Time Slip 1/4
.538 - Reaction
2.353 - 60 FT
8.967 - ET @ 594 FT
9.555 - 1/8 ET
76.64 - 1/8 mph
14.636- 1/2 ET
95.11 - 1/4 mph
Old Sep 1, 2005 | 07:39 AM
hybrid69's Avatar
Default Re: Modify B16B Issue (hybrid69)
Programed P30 Ecu with a Modidy GSR.BIN for my setup.
Old Sep 1, 2005 | 07:57 AM
RagingAngel's Avatar
Post a dyno chart with AF readings.....
upgrading your injectors might not be necessary.... do you know what your duty cycle is or your current AFRs are?
Old Sep 2, 2005 | 07:23 AM
hybrid69's Avatar
Default Re: Modify B16B Issue (RagingAngel)
I guess i found my answer in the rc injectors website. They have a equation to calculate what type of injector you need for your engine horsepower
(Horsepower X B.S.F.C) / (Duty Cycle X .80) = X.X Lbs/Hr
(190 x .50) / 3.2 = 29.69Lbs/Hr
Since injectors are measure in CC you must change the Lbs/Hr to CC with this Eq.
X.X Lbs/Hr / 10.50 = X cc
29.69 X 10.50 = 311.745 cc/min
Old Sep 2, 2005 | 09:57 AM
UncleD's Avatar
I wanna know how you got 12.5 compression out of your motor.....did you cut the head?
Old Sep 2, 2005 | 10:44 AM
Grand's Avatar
what car is this in
Old Sep 2, 2005 | 03:15 PM
hybrid69's Avatar
Default Re: Modify B16B Issue (clean rice)
yes the head was cut 20mm plus am using flat ferreas valves that helps to push up the compression.
Old Sep 2, 2005 | 03:16 PM
hybrid69's Avatar
Default Re: (LG_R32)
This setup is in a 1992 Civic Si Hatch..
Old Sep 2, 2005 | 05:21 PM
PyroProblem's Avatar
Default Re: (hybrid69)
I think you should be pushing more power out of that thing with the mods you have done...
If your injectors are just barely too small for your intended HP, you can always raise the pressure a bit.
But then again bigger injectors will give you room to grow!
itr1244
Jul 19, 2018 06:27 AM
phyzJunkieCivic
Nov 5, 2006 11:01 PM
dubniK
Mar 7, 2004 10:31 PM
DailyBlown
Aug 3, 2003 08:00 AM
slowsi00
Nov 14, 2002 11:41 AM
