viper alarm won't dis-arm itself
Old Sep 1, 2005 | 06:59 AM
Easyslider01's Avatar
Default viper alarm won't dis-arm itself
I have a viper alarm, the one with the non-digital remote, and it works fine with a while, then it seems to not dis-arm itself once and while, I dont know if it has to do with the climate or what. Today there was alot of morning dew on my car and it wouldnt dis-arm itself, i ended up walking to work. Its happened once before that on a really hot day. If I leave the car for a few hours and come back it seems to work. any ideas?
Old Sep 1, 2005 | 10:59 AM
fcm's Avatar
fcm
Old Fart
Default Re: viper alarm won't dis-arm itself (Easyslider01)
It may be a problem with a cold solder joint, [poor connection] in the RF section, [the part that receives the signal from the remote] of the alarm, or if it has a plug in ant. it could be the ant. itself or the connection to the alarm.
Try this, next time it will not disarm, try the manual override to turn off the alarm. 94
Old Sep 1, 2005 | 11:08 AM
Default Re: viper alarm won't dis-arm itself (fcm)
how do i do the manual over ride
Old Sep 1, 2005 | 04:11 PM
fcm's Avatar
fcm
Old Fart
There should be a small push button momentary switch under the dash some place, turn on ign. push and hold the button till alarm stops. Do you know what model it is? 94
Old Sep 1, 2005 | 08:54 PM
Jdm94gsr's Avatar
how bout you check you battery inside your key fob
Old Sep 2, 2005 | 06:36 AM
Default Re: viper alarm won't dis-arm itself (Jdm94gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm94gsr &raquo;</TD></TR><TR><TD CLASS="quote">how bout you check you battery inside your key fob
I did that
Old Sep 2, 2005 | 09:39 AM
fcm's Avatar
fcm
Old Fart
Did you find the "valet" switch?
Do you know the alarms model? 94
Old Nov 5, 2005 | 03:29 PM
the fcc id is : EZSDEI487 today the alarm worked from about 10 feet, then an hour it dosent work at all? I changed the batteries again.
Old Nov 5, 2005 | 04:14 PM
fcm's Avatar
fcm
Old Fart
Did you not get 2 remotes with the alarm? 94
Old Nov 7, 2005 | 02:36 AM
no just 1 remote
Old Nov 7, 2005 | 11:12 AM
fcm's Avatar
fcm
Old Fart
Was the alarm in the car when you got it, [the car]?
All DEI alarms come with 2 remotes, here in Canada anyway.
If you had a second remote you could eliminate the remote as the problem 94
Old Nov 7, 2005 | 01:21 PM
yea it came with the car.
Old Nov 8, 2005 | 08:58 AM
fcm's Avatar
fcm
Old Fart
Oh so somebody out there has a remote for your alarm
At this point what I would do is, get another remote erase all remotes and program the new one and reprogram the one you have, If the new remote gives you no problems, you will know it was your old remote that was the problem, or you can pull the alarm and ant. and send them along with your remote to DEI and have them check it out, as the alarm came with the car, you have no warranty on it so anything you do is going to cost you.
It may be time to think about a new alarm, get it and have it installed at an authorized dealer, that way you will get a lifetime warranty on the alarm, [one year on remotes] and the main thing is the lifetime warranty on the install, so the next time you run into a problem, they will deal with it. 94
Old Nov 8, 2005 | 03:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Oh so somebody out there has a remote for your alarm
It may be time to think about a new alarm, get it and have it installed at an authorized dealer, that way you will get a lifetime warranty on the alarm, [one year on remotes] and the main thing is the lifetime warranty on the install, so the next time you run into a problem, they will deal with it. 94</TD></TR></TABLE>
thanks for the info, I'm trying to avoid buying a new alarm. The guy that had the car before me was an alarm installer and he did a good job doing a stealth install. Also I multiple kill switch's to slow them down. I'm gona try a new remote. Will my friends remote work if we reprogram it, its the next level up with the lcd interface.
Old Nov 8, 2005 | 04:18 PM
fcm's Avatar
fcm
Old Fart
Go here to find out what remote will work on your alarm, http://www.directed.com/guides/transref.asp 94
Old Nov 12, 2005 | 06:51 AM
monstaxmatt's Avatar
your antenna is badd thats the same thing that happened to me
Old Nov 13, 2005 | 08:03 AM
Default Re: (ilovemyhonDA9)
where can I buy a new one
Old Nov 14, 2005 | 09:16 AM
suspendedHatch's Avatar
Default Re: (Easyslider01)
ebay duh.
ohsnapzafingcu
Audio / Security / Video
13
Feb 9, 2009 11:46 AM
Dr. Willy
Aug 11, 2008 12:53 AM
rdssk8rcs1
Feb 21, 2007 09:52 PM
Krayzielix
Sep 15, 2006 09:45 AM
integraguy2001
Dec 22, 2004 12:50 PM
