Swapping ECUs! *Easy quick question*
Old Aug 31, 2005 | 10:35 PM
Makdaddynuge's Avatar
Default Swapping ECUs! *Easy quick question*
These gas prices are out of my mind. I need to do something about it quick. The ecu i am running right now runs very rich, it has to come out. I have a 94 civic dx hatch. The car was originally an auto and when the gsr was put in, it was converted to a 5 speed.
I have a VIRGIN AUTOMATIC P28 ECU lying around, could i put that on the car and it will run ok? I only want it for the stock gas-happy map on it.
Edit: While on the subject, does aftemarket exhaust affect gas mileage at all?
Your input is greatly appreciated, thanks.
Modified by Makdaddynuge at 9:10 AM 9/1/2005
Old Aug 31, 2005 | 10:47 PM
Luserkid's Avatar
Default Re: Swapping ECUs! *Easy quick question* (Makdaddynuge)
Itll throw a code for auto **** but other then that i heard it runs the same.
Old Sep 1, 2005 | 07:10 AM
anyone else, i like getting some more opinions please.
Old Sep 1, 2005 | 07:15 AM
IHateJDM's Avatar
Default Re: (Makdaddynuge)
i would bet it would run on the lean side, so maybe back off your timing a little too, but you should be ok.
Old Sep 1, 2005 | 07:40 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Swapping ECUs! *Easy quick question* (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Itll throw a code for auto **** but other then that i heard it runs the same. </TD></TR></TABLE>
Yup, just a code for that pesky automatic shift solenoid. But other than that, it will run fine.
Old Sep 1, 2005 | 08:10 AM
Default Re: Swapping ECUs! *Easy quick question* (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">i would bet it would run on the lean side, so maybe back off your timing a little too, but you should be ok.</TD></TR></TABLE>
Does anyone else feel this way or have experience with this?
Old Sep 1, 2005 | 08:33 AM
Relic1's Avatar
which ECU are you running now?
a Stock P28 would run a GSR on the lean side.
I'd just burn a stock GSR map in uberdata or Crome and drop it in there. Heck have it tuned so it runs right which will get you better fuel mileage and more power.
Old Sep 1, 2005 | 10:06 AM
i'm running a chipped p28.
I don't know what to go by, some people say it will run fine, others say it will be too lean.
Old Sep 1, 2005 | 10:22 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Makdaddynuge &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what to go by, some people say it will run fine, others say it will be too lean.</TD></TR></TABLE>
It is fine. I have done three auto to manual swaps and in all 3 cases, I have kept the stock automatic ECU. One was on my Integra, and two were on EX Civics (one swapping to a 5-speed H22).
I have heard they run lean, but in my experience, even in tuning, they didn't exhibit any signs of this.
Old Sep 1, 2005 | 10:39 AM
B_CRUZ!'s Avatar
Default Re: (shamoo)
a stock automatic p28 is bad for a gs-r motor.
you think the air/fuel for a 1.6 sohc is safe for a 1.8 dohc?
get your self a stock 94-95 p72
Old Sep 1, 2005 | 10:47 AM
Easyslider01's Avatar
Default Re: (I have a big)
i have a usdm and jdm p72 for sale, let me know. OBD1
95dc2teg
Jun 5, 2008 02:32 PM
BLacK FirE
Jul 8, 2006 08:04 AM
Jan in Omaha
10
May 12, 2005 04:43 PM
Toda Built
Jan 15, 2004 05:52 AM
turbotime
Nov 29, 2003 03:53 PM
