Unsolved Problem?b20 vtec
Old Aug 31, 2005 | 10:26 PM
shtalker's Avatar
Default Unsolved Problem?b20 vtec
Heres the problem a lot of people have tried to fix but can t find a solution. The car dies everytime I make a stop. Heres the set-up:
b20 block
bore 84.5
Super tech pistons/ 12.5 comp
Stock rods
Old school gsr head i think (pr3-3)
Super tech (valves,springs,retainers)
Skunk 2 - Stage 2 cams
Stock b16 camgers
RC 310 injectors
Stock fuel pump
Aasco flywheel
Compleate Hyper Clutch 4-puck
GSR Tranny/ATS 4.9 final drive/Spool
Well thats the whole set up, a couple of local shops have tried to fix it but they cant find a solution to it. The motor doesnt have more than 20 miles on it, every since the motor was built this problem has happened. The car hasnt been tuned, right now its running on a chipped p28 and obd2 wiring harness if it matters. I would appreciate any kind of help from you guys. If yall have any kind of question, please feel free to ask. Thanks
Modified by shtalker at 12:33 AM 9/1/2005
Modified by shtalker at 7:56 PM 9/5/2005
Old Sep 1, 2005 | 12:19 AM
KillerTofu's Avatar
Default Re: Unsolved Problem?b20 vtec (shtalker)
Obviously you have spark and fuel. Try checking all the electrical connections, grounds and so forth. Do you have a fluke? Try a continuity test. Maybe something is coming lose. Sorry I cant be of more help. Goodluck.
Old Sep 2, 2005 | 10:34 AM
RudeBwaiSi's Avatar
Is it getting enough fuel with the chipped P28 ECU? Does it startup and idle nice, or does it shut off after idling for a while. Cause I had this proble with the car shutting down after idling for a while; found out there was a small vacuum hose not connected on the back of the intake manifold. And also one of the sensors was connected the wrong place. . . I think its the TPS and MAP. . .check those connections.
Old Sep 2, 2005 | 04:45 PM
IMALLSLO's Avatar
Check valve adjustment. Tight valves will cause a bad map reading and stalling. Depending on what year car it is(assuming 92-95 civic) youll be able to mointor the map reading through a scantool. If the valve lash is ok to spec according to Skunk,check that your IAC valve is working properly. If not replace that and perform idle relearn. Make sure noone has touched the screw under the throttle body. This is a cheap method of adjusting the idle and will throw base TP sensor readings off thus causing a stall. At idle TP readings should be around .45 closed car off key on. I need a little more info on car/year to diagnose further.
Old Sep 2, 2005 | 05:38 PM
shtalker's Avatar
I really appreciate all the help u guys have giving me, every bit of info yall give me its really helpfull.
I've been told that the head im running its a itr head, the idle screw its not under the throttle body but on the side, we have messed with it but the problem it still happens, the previous car that was running this head had the same problem and thye use to play with the screw until the problem would stop, but we have tried it and it doesnt work
What kind of extra info do yall need???
Old Sep 2, 2005 | 07:11 PM
non-VTEC's Avatar
how does it stall when stopping.....clutch in and the revs drop right down?
if you blip the throttle while not moving will it drop down and stall also or will it just idle fine? does the idle bounce up and down allot when you blip the throttle before settling down to the correct idle speed?
i think i know what your problem is depending on how you answer some of my questions but i wanna make sure.
Old Sep 3, 2005 | 11:54 PM
Supahr_Ed's Avatar
does it feel like a fuel problem, does it choke a little, then idle drops? Reminds me of a clog fuel filter, maybe the chipped p28 is running way too lean or rich.....So when your at a stop, the air/fuel ratio is all off....
Old Sep 4, 2005 | 12:22 AM
shtalker's Avatar
Thanks guys for all the tips, the car doesnt stall at all, once I take my foot off the gas the car goes off, as simple as that. The car idles fine no problem what so ever. Im running a AEM regulator and fuel rail, I heard that regulator its not good, do yall think thats the problem??? I'll try to post some pics of the motor( throttle body screw and all that). Im using a obd2 harness and there are some plugs that are not been used, so I'll like to knowif I'm using the right ones and which ones r of no need .I really thank everybody that have posted tryin to help me. I'll try to post some pics tomorrow, see if that helps. Thanks
Old Sep 4, 2005 | 04:45 AM
MikeNice's Avatar
are you getting any CEL. check your sensors cause my map sensor was bad and it kept dying out. It might sound stupid but check your bolts on the intake manifold cause my friend once put in a Skunk2 manifold but didn't tighten all the bolts and his car kept dying and once and tighten them all, the car started.
Old Sep 4, 2005 | 11:52 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: Unsolved Problem?b20 vtec (MikeNice)
it's when you come to a stop it does it? or does it do it in neutral too?
Old Sep 5, 2005 | 07:06 PM
shtalker's Avatar
Default Re: Unsolved Problem?b20 vtec (turbofienD 04)
The car dies as soon as I start slowing down. Lets say im rollin on 50 mph and I see i gotta slow down, I put it on neutral and start hitting the brake the car dies. I already have some pics of the motor, throttle body and plugs but I dont know how to post them, so if you want to help me please private message me your email and ill email them to you. Thanks to everybody tryin to help.
Old Sep 5, 2005 | 11:33 PM
rev-speed's Avatar
open up ur butterfly
the adjustment screw is the stopper screw on ur throttle
then adjust ur tps to spec.
Old Sep 6, 2005 | 07:33 AM
MrAngry's Avatar
what is the timing currently set to?
Old Sep 6, 2005 | 09:38 PM
CTR_EK's Avatar
Default Re: (MrAngry)
send me pics to ctr_usdm@yahoo.com
Old Sep 6, 2005 | 09:42 PM
shtalker's Avatar
The timing its currently set on 15
Old Jul 27, 2024 | 02:15 PM
nate99ek's Avatar
I need help . My 99ek has a b20b bottom pr3-3 head . It has a skunk 2 intake manifold and aem fuel rail aem fuel pump s300 homdata p28 ecu . I got this car a couple weeks ago been driving fime sluggish in low rpms said it needed a tune and would be fine . Today anytime i accelerate it wants to cut out and back on and doesnt want to go over 40 or 50 or so and nothing high rpms now. Idk what to do please help
Old Jul 27, 2024 | 04:01 PM
theYBLEGAL's Avatar
Loved
Check yer plugs, prob start a new thread, this one is unrelated and 19 years old
​​​​And go get a tune before you break it
jdragon1974
51
Sep 5, 2013 09:47 AM
SiRstewart99
Aug 24, 2012 08:04 AM
Ruy
21
Feb 18, 2012 01:17 PM
darrinbrewer
Jan 23, 2006 05:57 AM
iamthemouse
Jul 26, 2004 05:19 AM
