Plugging a hole in the tire...a reliable method?
Old Aug 31, 2005 | 07:20 PM
stickercuttingcom's Avatar
Default Plugging a hole in the tire...a reliable method?
I seemed to of ran over a rock and it is rammed between the tread of my tires and it is causing a slow leak. If the rock comes out, I am up the creek with a flat tire, so I need to get this fixed asap. Do the plugs that they sell work well enough to warrant fixing it? It is a 215/45/17 tire so I want to see if I can fix it before buying a new tire.
I have seen the plug kits but I wasn't sure how reliable they were for the long haul. The hole doesn't look to be huge, but it isn't a pin hole either.
Thanks!
Old Aug 31, 2005 | 07:21 PM
ROK801's Avatar
Default Re: Plugging a hole in the tire...a reliable method? (stickercuttingcom)
on a 45 series?
kinda scary, but its do-able.
dont go on a long trip without a new tire...
Old Aug 31, 2005 | 07:23 PM
FalkenSiR's Avatar
Default Re: Plugging a hole in the tire...a reliable method? (ROK801)
Just take it to a tire shop man. They usually charge 5 bux to fix it. (where I live)
Old Aug 31, 2005 | 07:26 PM
Yea I know that is an obvious option, but I wanted to hear other experiences for the long haul as I haven't had them fix a low profile tire before.
Flat tires + lowered cars and living in the mountains can = stranded if you can't a jack under the car So I want to be as careful as possible.
Old Aug 31, 2005 | 07:46 PM
new2novas's Avatar
Default Re: (stickercuttingcom)
i am a mechanic and we put em in tires all the time, just put one in a 40series beemer tire. I would do it on my own tires if it were them....they are probably better than the actual tire itself , go for it, save the $xxx.xx and spend it on the motor
actually take 5 or 10 bucks and get yourself a tire repair kit from whatever autoparts store you like most and keep it in the glovebox, you will thank me when you get a flat in bumble and you can get air for your tire, but no tire repair man in sight
Old Aug 31, 2005 | 08:50 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (new2novas)
I've used repair kits all the time. Never had a problem, and I've used them on stock tires, 40 series, 35 series, etc. If you put them in nicely, they will last the life of the tire.
Keep in mind they only work on the tread area and not the sidewall.
Old Aug 31, 2005 | 08:55 PM
FMIDRC Racer's Avatar
i'd take it to a tire shop and have them patch it. rocks don't leave round/uniform holes and the plug could still leak. if it was a nail or screw i'd just say plug it.
Old Aug 31, 2005 | 09:39 PM
JohnnyLux's Avatar
Default Re: (FMIDRC Racer)
deffinetly buy a plug. i plugged one tire about 5000 miles agoand it holds air better then the other three. plus it only costs about 5.00 for a good plug kit.
MrXclusivE
Sep 29, 2008 11:40 AM
team714
Jun 4, 2008 10:42 AM
imroadk1ll
Honda Civic (2001 - 2005)
21
Feb 28, 2007 05:00 PM
95TEG
Sep 14, 2005 04:04 PM
oMek
Mar 7, 2004 10:34 PM
