b16sir cv axels ?
I just got this 1990 crx with a b16sir engine swap, Im almost sure that the hubs were not changed with the engine. I was wanting to know what kind of axels i have to get if they were changed though. Ive been told a 1991 integra, but it all sounds a little fishy to me.
If you have an SiR engine swap then you don't use integra axles, at least not on the drivers side. You'll need a custom made/hybrid axle that is shorter. I heard 90-93 integra axle with 87-89 inner cv joint works. Of course this all depends on what intermediate shaft you have. If it's stamped "SK7" (integra), you can use the 90-93 integra axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx »</TD></TR><TR><TD CLASS="quote">use integra halfshaft and axles.............no matter what i have premature wear on passenger side axle............</TD></TR></TABLE>
Did you keep or remove the rubber rings on the end? just curious. I've read that you must remove them but when I did my axles they were installed so I left them on when I installed the new axles.
Hybrid axle: 90-93 Integra axle shaft mated with ED6 axle end in order to use ED6 spindle/hub assemb
integrawow
Jul 2, 2007 02:20 AM
ITR632
Apr 21, 2003 01:24 PM
shiithook
May 28, 2002 12:02 PM
