IF my tps sensor goes bad, can I use my vafc2 to compensate the change?
Old Aug 31, 2005 | 02:51 PM
ndlyng's Avatar
Default IF my tps sensor goes bad, can I use my vafc2 to compensate the change?
If my tps sensor goes bad, in which checking the voltage on closed/open throttle and is reading 5v on both. I think if tps sensor is bad, i can take it off and run without it but lose some power? Can my vafc2 compensate the loss of power?
Old Aug 31, 2005 | 03:47 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: IF my tps sensor goes bad, can I use my vafc2 to compensate the change? (ndlyng)
replace the ******* sensor.
Old Aug 31, 2005 | 05:04 PM
Quitripin's Avatar
save your self the hastle and relpace the sensor. you'll thank yourself in the future
Old Aug 31, 2005 | 08:30 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: IF my tps sensor goes bad, can I use my vafc2 to compensate the change? (EFB16ACRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFB16ACRX &raquo;</TD></TR><TR><TD CLASS="quote">replace the ******* sensor. </TD></TR></TABLE>
Old Sep 1, 2005 | 10:28 AM
amckee's Avatar
I think you are reading supply voltage from the harness. You need to be reading resistance from closed to open throttle and looking for dead spots.
cryingsuns
Mar 20, 2011 01:13 PM
kornerk12
Jun 15, 2007 04:01 AM
ef9_civic_hatch
May 13, 2007 03:50 PM
EFRue57
Sep 17, 2005 05:41 PM
