Outer Tie Rid Movement????????
Old Aug 31, 2005 | 02:47 PM
JDM_SOHC's Avatar
Default Outer Tie Rod Movement????????
Now don't worry I've read up, an done my research but I still have yet to found out one thing... Well when im just cruisin an start to put some heavy pressure onto the brakes, my car starts shaking very fast back n forth from the wheels it feels like.. Well my guess is it's possibly outer tie rod, because when I jacked up the car i could move the wheel a good 1/4" both way... Like it wobbled back an forth, but then I read that wheels well sometimes have a little play in them..?? Can anyone justify the amount of movement I should have? Because I'm not sure if maybe i have a ceized up caliper or something like that or if I should replace my tie rod.. Thanks...
Modified by JDM_SOHC at 4:46 PM 8/31/2005
Modified by JDM_SOHC at 4:47 PM 8/31/2005
Old Aug 31, 2005 | 02:57 PM
JDM_SOHC's Avatar
Default Re: Outer Tie Rid Movement???????? (JDM_SOHC)
bump
Old Aug 31, 2005 | 03:46 PM
JDM_SOHC's Avatar
::bump 2::
Davesmit
Jul 1, 2019 01:08 AM
EgK2o09
Suspension & Brakes
Feb 14, 2010 07:23 AM
supaman
Honda Civic (2001 - 2005)
Aug 28, 2008 05:16 PM
snatch
12
Jan 25, 2008 11:36 AM
ef_you
24
Jan 8, 2005 10:07 PM
