Window motor or track?
Old Feb 25, 2002 | 05:54 PM
M0NEYnH0s's Avatar
Default Window motor or track?
One of my windows has trouble going down, it goes down a part of the way then gets stuck and needs a little pushing till about 3/4 of the way to get it completley down. But rolling up it has no problems. Is this my window regulator? or what?
thanks
Old Feb 25, 2002 | 06:38 PM
Mike P.'s Avatar
25 Year Member
Default Re: Window motor or track? (m0neynh0s)
seems to me that it would probably be the track. You may need to lubricate the tracks. See if that works, as it's the most common problem. I just had to slip my driver's window back into it's front track the other day. I asked about it here and go the problem solved in about 10 minutes.
Old Feb 25, 2002 | 07:26 PM
M0NEYnH0s's Avatar
Default Re: Window motor or track? (Mike P.)
What kind of lub did u use? thanks again for the help.
Old Feb 25, 2002 | 07:52 PM
Audio18's Avatar
Make sure that you do try to lubricate the window track, because the resistance will cause the motor to break the metal rope that runs through the assembly. My windows kept slowing down on my Accord, and it eventually broke since I had the window rollup option on my alarm. The motor will work fine, but the track slows the thing down even though the motor keeps pulling
Trust me, prevents you from buying a $150 new one.
Old Feb 26, 2002 | 12:18 PM
M0NEYnH0s's Avatar
Default Re: Window motor or track? (Audio18)
what kind of lubricant should i use?
1baddcivicsi
Jul 31, 2009 06:27 AM
scootdigity
Jul 17, 2007 05:42 PM
loup05
Nov 22, 2005 12:07 PM
aZnjCC
11
Aug 16, 2004 07:51 PM
UpstateCivic
Aug 3, 2002 09:35 AM
