pr3 ecu.........need pin scematics............somebody.....anybody......... ..
you mean the pin-outs for the ecu harness?
i have a doc i got from somewhere with the pinouts.
i got it so that i can wire in the knock sensor that apparently has never been wired to the ECU.
google search is probably how i found it.
here it is:
<U>PW0/PR3 PINOUT</U>
A01 BRN INJ1 fuel injector control # 1
A02 BLK PG1 Ground
A03 RED INJ2 fuel injector control # 2
A04 BLK PG2 Ground
A05 LT BLU INJ3 fuel injector control # 3
A06 GRN purge cut-off solinoid valve
A07 YEL INJ4 fuel injector control # 4
A08 VTS VTEC solenoid
A09
A10 Pressure Regulator Cutoff Solenoid
A11 BLU/YEL IACV from electronic air control valve
A12 GRN/BLK FLR1 fuel pump control
A13 YEL/BLK IGP1 power Input
A14 GRN/BLK FLR2 fuel pump control
A15 YEL/BLK IGP2 power Input
A16 BRN/BLK ground
A17
A18 BLK/RED ground
B01 WHT/GRN VBP Battery Backup
B02
B03 YEL ACC a/c compressor clutch relay cont
B04 FANC
B05 WHT/YEL VTM VTEC pressure switch
B06 GRN/ORN MIL check engine warning light
B07
B08 YEL/GRN ACS a/c on input
B09
B10 ORN CYP P crank sensor (1)
B11 Fuse Box
B12 WHT CYP M crank sensor (2)
B13 BLU/WHT starting input
B14 BLU ALT alternator output signal
B15 WHT ignition output signal
B16 YEL/RED VSS VSS
B17 WHT ignition output signal
B18
B19 KS Knock sensor
B20 BRN SCS ignition timing adjusting connector
C01 BLU/GRN CKP P CYL sensor (1)
C02 BLU/YEL CKP M CYL sensor (2)
C03 ORN/BLU TDC P TDC sensor (1)
C04 WHT/BLU TDC M TDC sensor (2)
C05 RED/YEL IAT intake air temperature sensor
C06 RED/WHT ECT coolant temperature sensor
C07 RED/BLU TPS throttle angle sensor
C08 O2S Dual O2 Sensor (JDM)
C09 RED/WHT PA atomosphere pressure sensor input
C10 GRN/WHT BKSW brake light switch
C11 GRN/WHT MIL ground
C12 GRN/WHT SG2 TPS GND
C13 YEL/WHT VCC1 TPS 5V
C14 SG1 MAP GND
C15 YEL/RED VCC2 MAP 5V
C16 WHT O2S oxygen sensor
here it is:
A02 BLK PG1 Ground
A04 BLK PG2 Ground
A09
A16 BRN/BLK ground
A17
A18 BLK/RED ground
B02
B04 FANC
B07
B09
B11 Fuse Box
B16 YEL/RED VSS VSS
B18
B19 KS Knock sensor
C14 SG1 MAP GND
Powered By Garrett
Mar 30, 2008 08:44 AM
