Cooling Question...(new radiator)
Old Aug 31, 2005 | 03:42 AM
BDogggUT34's Avatar
Default Cooling Question...(new radiator)
I have a 92 Si with a B18b. I was having overheating issues and realized my stock D16z6 radiator was leaking so i just changed it out to a dual core del sol radiator. I used the bleeder screw to bleed air out the top and have had to refill the overflow a few times now. Question is, after driving for about 10 min the temp skyrockets but if i have the heat all the way hot and the blower on the 1 setting the temp goes back down to just below halfway. I'm not familiar with how the heater and such works, but what i'm wanting to know is "is this a thermostat problem or do i still have an air bubble somewhere in there?" Do i just need to let the engine run w/o the radiator cap and wait? I just want to be sure before i buy something that is not broke, thanks!
Old Aug 31, 2005 | 03:45 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Cooling Question...(new radiator) (BDogggUT34)
Let's bleed the system to fully assure ourselves that there are no air bubbles.
Take off radiator cap
Seat heat to full blast
Turn car on
Let it idle for a good 15-20min
Watch as the air bubbles escape out the open radiator
Fill with additional coolant/water as necessary
This should stop your problem
Old Aug 31, 2005 | 03:48 AM
BDogggUT34's Avatar
Default Re: Cooling Question...(new radiator) (litterbox)
will do! What are symptoms of a bad thermostat? Also, when you say set heat to full blast , do you mean the temp and turn the blower to full blast? Or it may not even matter
Old Aug 31, 2005 | 03:54 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 &raquo;</TD></TR><TR><TD CLASS="quote">will do! What are symptoms of a bad thermostat? Also, when you say set heat to full blast , do you mean the temp and turn the blower to full blast? Or it may not even matter </TD></TR></TABLE>
When the car reaches normal temperature, feel the lower radiator hose. It should be hot. If it's not, something is wrong.
Heat = hot and full blast.
Old Aug 31, 2005 | 03:57 AM
BDogggUT34's Avatar
i'll do this and check back later on. Thank you!
Old Aug 31, 2005 | 04:03 AM
litterbox's Avatar
Post the results.
Old Aug 31, 2005 | 01:47 PM
BDogggUT34's Avatar
well, i did get quite a few bubbles out of there. I topped off the radiator and took it for another ride for about 15 min. At idle, the temp needle still sticks around 3/4. Occasionally it will go at half but then will go back up to 3/4. Radiator fan occasionally comes on also. The top radiator hose is hot to where i cant keep a finger on it, the bottom is just warm?!! I'm starting to think it can only be a thermostat problem now. Any suggestions??
Old Aug 31, 2005 | 02:01 PM
b 1 6 a 2's Avatar
Change the thermostat and re-bleed the system.
Old Aug 31, 2005 | 04:41 PM
BDogggUT34's Avatar
Default Re: (b 1 6 a 2)
aight now, looking on Autozone.com for prices i noticed there are thermostats that are low temp (170 degree), med temp (180 degree) and high temp (192 degree), is there a certian one i should get? Also some say that they are designed to LOCK open at 280 degrees to provide maximum cooling, would this be something i would want or should i not bother the extra $5? thanks, first time changing thermostat in case you haven noticed
Old Aug 31, 2005 | 05:06 PM
b 1 6 a 2's Avatar
Get Honda OEM
Old Aug 31, 2005 | 05:13 PM
jdmstreet88's Avatar
should work
Old Sep 1, 2005 | 04:12 AM
BDogggUT34's Avatar
Default Re: Cooling Question...(new radiator) (jdmstreet88)
anyone know how the heating system works? Like why my temp can stay at half or a little below when i have the heat on hot but the blower still off?
Old Sep 1, 2005 | 09:32 AM
BDogggUT34's Avatar
anyone know the heating question?
Old Sep 1, 2005 | 10:20 AM
jspecjoe's Avatar
I dont know the answer but have the same problem with my ITR swap . With the heat on its 3clicks from middle with it off it 1 click below middle or slightly higher but no flucuation during driving, just when heat is on, I am gonna check the lower hose temp.
I do run a spoon thermostat so maybe this is normal????
Old Sep 1, 2005 | 04:37 PM
BDogggUT34's Avatar
Default Re: (jspecjoe)
well, after driving for a day now, i think i will just keep the temp over to hot! I dont have A/C anyway so...., i would still like to know why it does that.
Old Sep 6, 2005 | 10:47 AM
jspecjoe's Avatar
anyone know why I run mid way when heat dial on cool , but run 1/4 up from cold when on heat? is this a bubble in the coolant?
Old Oct 13, 2005 | 08:40 AM
BDogggUT34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 Si with a B18b. I was having overheating issues and realized my stock D16z6 radiator was leaking so i just changed it out to a dual core del sol radiator. I used the bleeder screw to bleed air out the top and have had to refill the overflow a few times now. Question is, after driving for about 10 min the temp skyrockets but if i have the heat all the way hot and the blower on the 1 setting the temp goes back down to just below halfway. I'm not familiar with how the heater and such works, but what i'm wanting to know is "is this a thermostat problem or do i still have an air bubble somewhere in there?" Do i just need to let the engine run w/o the radiator cap and wait? I just want to be sure before i buy something that is not broke, thanks! </TD></TR></TABLE>
just for future reference, problem was thermostat! FIXED
matt203
May 14, 2013 08:16 PM
1992honda
Oct 2, 2011 03:00 PM
G2_Fella
Apr 23, 2008 12:28 PM
dlo102106
Sep 28, 2007 03:44 PM
TenaciousC
Aug 22, 2002 02:11 PM
