b16a vs b16a2
Old Aug 30, 2005 | 08:37 PM
Jesterian's Avatar
Default b16a vs b16a2
Besides the redline difference, how is the a2 .. "better"?
Old Aug 30, 2005 | 08:46 PM
SiR Inspired ED7's Avatar
Default Re: b16a vs b16a2 (Jesterian)
are we speaking jdm wise about 1st gen and 2nd gen or.... 1st gen b16a (jdm) vs b16A2 (usdm) ?
EL Vap133's Avatar
Newer?
Old Aug 30, 2005 | 11:23 PM
Contender25
Guest
Posts: n/a
the b16a is 10:2 and the b16a2 is 10:4, so it has like.....pfft 10 more hp, still not enough to move a Eg's Fat *** past my Crx stock to stock.
Old Aug 30, 2005 | 11:52 PM
TH33G4MON3's Avatar
Default Re: (Contender25)
b16a is like 160hp and the b16a2 is 170... I guess its just the little things that make the 10 hp difference... b16a2
Old Aug 30, 2005 | 11:55 PM
Default Re: (TH33G4MON3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TH33G4MON3 &raquo;</TD></TR><TR><TD CLASS="quote">b16a is like 160hp and the b16a2 is 170... I guess its just the little things that make the 10 hp difference... b16a2 </TD></TR></TABLE>
converting obd 0 to obd1 made the difference or not?
Old Aug 31, 2005 | 12:03 AM
Malgerus's Avatar
Default Re: (88 Crx Si)
The B16A2 has slightly better cams, bigger intake manifold, 60mm throttle body (vs 58mm on the 1st gen), better ECU (OBD-I), and thus makes more hp, and peaks at a higher RPM (7800 vs 7600).
Old Aug 31, 2005 | 12:32 AM
TH33G4MON3's Avatar
yes obd1
Old Aug 31, 2005 | 04:02 AM
smutmonger's Avatar
it kinda depends on which b16a2 you are talking about
my b16a (jdm xsi motor) is 170
my b16a2 (00 si motor) is 160
Coldth1
63
May 18, 2016 11:59 AM
JustEFit
Dec 29, 2012 07:16 AM
mynameizstitch
Jul 26, 2010 06:48 AM
JJGL-EF90
10
Feb 7, 2010 06:16 PM
ulemu
Jan 9, 2006 04:28 PM
