What size injectors for my application?
Old Aug 30, 2005 | 07:41 PM
gtturborex's Avatar
Default What size injectors for my application?
Like the title says, I've got a built turbo b20vtec and i'm looking for around 600whp. also i would like to know the difference between saturated and peak and hold injectors.
Thanks,
Mike
Old Aug 30, 2005 | 08:13 PM
SpdFrk's Avatar
Default Re: What size injectors for my application? (gtturborex)
Saturated injectors- no resister box needed.
P&K injectors- you'll need a resistor box.
You'll need atleast 900cc injectors if not more if your planing on making 600whp. Will u be running a 255 intank pump or an external fuel pump?
Old Aug 31, 2005 | 12:51 PM
gtturborex's Avatar
Default Re: What size injectors for my application? (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">Saturated injectors- no resister box needed.
You'll need atleast 900cc injectors if not more if your planing on making 600whp. Will u be running a 255 intank pump or an external fuel pump?</TD></TR></TABLE>
i have a walbro 255ho in tank already. can i use the stock resistor box or do i have to get an aftermarket one? i was thinking about getting 1000cc injectors, but i just wanted to make sure.
Thanks,
Mike
Old Aug 31, 2005 | 01:12 PM
95lstegman's Avatar
your other option is to get smaller injectors and either tap the manifold right behind the main 4 for 4 additional injectors or tap it at the t/b end for 1 or 2 additional injectors and either get a custom ECU or an additional injector controller. this way you can have 4 smaller injectors running all the time. smaller injectors = better fuelling under light load conditions, especially if you're in the ballpark of 1000cc. just my 2 cents.
Old Aug 31, 2005 | 05:48 PM
SpdFrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtturborex &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks,
Mike</TD></TR></TABLE>
Stock resistor box will do.
Old Sep 1, 2005 | 07:20 PM
95lstegman's Avatar
or you can DIY yourself one really cheap if you don't want to pay for a stock one and don't have one handy.
Old Sep 1, 2005 | 08:26 PM
gtturborex's Avatar
Default Re: What size injectors for my application? (95lstegman)
ya i already have one laying around. thanks
Steeve_Civic
Dec 4, 2011 10:11 AM
b16bri
Sep 5, 2010 02:53 PM
columbushatch
Jan 17, 2009 11:08 AM
DrivinVtec
Sep 17, 2007 10:08 AM
thid92
Aug 10, 2003 08:23 PM
