Electrical problem, batt light off!
Old Aug 30, 2005 | 05:01 PM
EFMAN's Avatar
Default Electrical problem, batt light off!
I've searched but can't find a clear answer. I've got a 91 CRX that doesn't appear to be charging, but the battery/charging light doesn't come on after the car is srarted. I can start the car with jumper cables, but when i take them off the car dies. This leads me to believe that the altornater is bad, only problem with this theory is that the battery light goes off when car is running. Any ideas, this is really pissing me off!
Old Aug 30, 2005 | 05:02 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Electrical problem, batt light off! (EFMAN)
does it come when keyon engine off?
Old Aug 30, 2005 | 05:26 PM
EFMAN's Avatar
Default Re: Electrical problem, batt light off! (DieMaster)
yes
Old Aug 30, 2005 | 05:30 PM
MENACE's Avatar
Did you try a new battery? Or at least have the one your using tested. It might be completly Shorted out and pulling such a big draw from you ALT, that the car cant run. Seen it happen a few times befor. I would check there First then check for amperage at the wires.
Old Aug 30, 2005 | 06:45 PM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: Electrical problem, batt light off! (MENACE)
is the battery relocated?
Old Aug 30, 2005 | 07:08 PM
sam385's Avatar
bad battery?
Old Aug 31, 2005 | 06:05 AM
Cornercarver78's Avatar
Default Re: Electrical problem, batt light off! (sam385)
yup, the battery is relocated to the back, and i've already switched batteries. Any ideas?
Old Aug 31, 2005 | 06:06 AM
sorry, my little brother was logged on when I made this post!
Old Aug 31, 2005 | 08:12 AM
Default Re: Electrical problem, batt light off! (Cornercarver78)
Would it be worth it to try another alternator even though the charging light goes off? Bump
Old Aug 31, 2005 | 08:56 AM
just took a turn for the worst. Now the car won't even hit. It just turns over I think I may have to just set the F@CKER on fire. Last time I was this Pissed I had to go to the ER for a broken hand F@CK!!! anyhow if anyone has any advice i'd love to hear it before I commit suicide
84Riceeater
Jun 30, 2015 06:56 PM
SPOONfed-Rex
10
Jan 15, 2009 08:06 PM
MDAnhorn
Dec 28, 2007 04:15 AM
srswarts3
Aug 6, 2005 03:47 PM
biggdogg
18
Nov 26, 2003 06:32 AM
