b20 vtec ecu/tuning question
Old Aug 30, 2005 | 04:45 PM
toooslow's Avatar
Default b20 vtec ecu/tuning question
I recently had a b20vtec built, stock bottom end, gsr head, ctr cams, stock fuel system and chipped p72 ecu. compression is about 10.8. My question is could i run a stock p72 ecu and not run too lean to hurt anything if i kept the rpms under like 4000. The engine is basically stock so i dont see why it wouldnt. Im gonna try to pass smog, (not the visual of course. ) other option is maybe trying to tune it with a vafc and wideband.
Any input would be great, thanks.
Old Aug 30, 2005 | 04:52 PM
drdisco69's Avatar
Default Re: b20 vtec ecu/tuning question (toooslow)
If you have a way to turn up the fuel pressure, you will be ok. Otherwise I might be concerned with a bit of detonation, and lower RPMs have more of a tendancy to detonate, in fact. The wideband is a great idea, and the VAFC will work in a pinch, although it can't replace really tuning the ecu.
Old Aug 30, 2005 | 05:19 PM
toooslow's Avatar
Default Re: b20 vtec ecu/tuning question (drdisco69)
The chipped ecu is running extremely rich right now. i dont have an fpr to tune fuel pressure though.
Does anybody know what generates better smog results, perfect stoich, a lil rich or a lil lean?
shermanyang
Honda CR-V & Element
14
Apr 17, 2013 05:00 PM
erikiksaz1
Engine Management and Tuning
Jun 11, 2010 02:39 PM
dmingis
Jun 29, 2008 07:30 AM
nd8ch
Feb 11, 2003 05:02 PM
Black R
Feb 18, 2002 10:12 AM
