problem(pictures inside)
It more than likely the gasket on the water pump tube. It run along the back side of the block. Theres 2 bolts that hold it in place at the thermostat housing. Undo them, and pull the tube out. Replace the O-ring and see if it fixed it. The loacation youre saying it dripped is right where that o- ring is. I dont tihnk its the water punp. It would be leeking down alot lower, and shoouldnt be getting on the alt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">weep hole in the pump</TD></TR></TABLE>
Happened to me! track the source.... there you will see your answer
RenoRacing
Oct 28, 2002 04:52 AM
