what should i do with my brakes?
Old Feb 25, 2002 | 03:58 PM
Mr.Squeeze's Avatar
Default what should i do with my brakes?
being that i have a 94s lude and i'm puting in a 93vtec motor fully build in and sence the s does not have ABS brakes should i just up grade to vtec rotors and calipers or should i buy a big brake kit
Old Feb 25, 2002 | 04:01 PM
JG Luder's Avatar
Default Re: what should i do with my brakes? (Mr.Squeeze)
do you brake hard alot?
Old Feb 25, 2002 | 05:00 PM
kevie88's Avatar
Default Re: what should i do with my brakes? (JG Luder)
That's the same question I had, here's what I'm doing. Check it out!
https://honda-tech.com/zerothread?id=134651
[Modified by kevie88, 10:52 PM 2/25/2002]
Old Feb 25, 2002 | 05:39 PM
Mr.Squeeze's Avatar
Default Re: what should i do with my brakes? (kevie88)
i do my share of 100+ from time to time on the h-way but its not like i do that every day it just with all the work done on my car i'm just wondering if i would be able to stop
Old Feb 26, 2002 | 05:30 AM
TimeRacer's Avatar
Brakes are the most neglected modification on a car. Everyone wants to go fast, no one wants to stop. But if you're not doing any heavy mountain runs, or racing of sort just go with new pads, lines, and fluid. If you're planning on doing something go with the Legend GS / NSX upgrade. I think kev will tell you it kicks *** when he gets it in.
~Doug
Old Feb 26, 2002 | 08:42 AM
Honda318dx's Avatar
Default Re: what should i do with my brakes? (TimeRacer)
just get VTEC rotors, and either 4th gen VTEC, 5th gen prelude, ITR, NSX, or Legend Calipers, and of course, true hi performance pads, mainly from http://www.carbotecheng.com
Old Feb 26, 2002 | 03:30 PM
TimeRacer's Avatar
Default Re: what should i do with my brakes? (Honda318dx)
Is the ITR/4th Gen VTEC/5th Gen system worth it? Isn't it more cost efficient to just go straight to the NSX/Legend setup from the start? They both fit under stock rims, is the price difference that high between the two?
~Doug
Old Feb 26, 2002 | 07:39 PM
Honda318dx's Avatar
~Doug
Well, yea but dual piston calipers wno't really help much for STREET applications, you will get just as much braking force out of a single piston.. Now, for track driving, dual would be better.... All in all, they all use the same pad, so not to big of a difference..
Old Feb 26, 2002 | 09:11 PM
boomslang's Avatar
You can use CRV calipers too, they are the same as the 5th gen prelude.
Old Feb 26, 2002 | 11:59 PM
TimeRacer's Avatar
True true, just wondering since I didn't think the price differnece would be that high. But I'm also one who says "do it once, do it right."
~Doug
[Modified by TimeRacer, 12:59 AM 2/27/2002]
Johnny.
Mar 22, 2009 07:34 AM
speedfreek128
14
Feb 26, 2009 10:01 PM
gitrdone
Honda Civic (2001 - 2005)
Jul 13, 2006 08:10 PM
97dc2
May 14, 2006 08:23 PM
