What Causes a head to get Warped?????
Old Aug 30, 2005 | 12:13 PM
JOGADOGGZ's Avatar
Default What Causes a head to get Warped?????
Question everyone, I have a High compression B16a Obd0 and it over heats at hard driving. What causes my head to get warped if i haven't raced or taken my car to redline at all??
Old Aug 30, 2005 | 12:17 PM
D15Bbigred's Avatar
well pretty much heat, caused by detonation i thought, if ur head is actually warped i'd get it resurfaced before u mess something up. hopefully ur block isn't warped.
Old Aug 30, 2005 | 12:19 PM
Suck my DX's Avatar
Default Re: What Causes a head to get Warped????? (JOGADOGGZ)
im sure there are a bunch of things that can cause a head to warp....but i only know two things for sure
overtorquing ur head bolts..
torquing ur head bolts in the wrong sequence..
maybe in the past the HG was burned and was driven like that for a while causing the head to get warped...
people correct me if i am wrong
Old Aug 30, 2005 | 12:25 PM
Reelizmpro's Avatar
Default Re: What Causes a head to get Warped????? (Suck my DX)
Overheating, torquing down in wrong sequence, inconsistent torque values for the headbolts are common causes.
Old Aug 30, 2005 | 12:26 PM
JOGADOGGZ's Avatar
yikes......if the motor is high compression, nothing less than 94 octane gas will do then?
Old Aug 30, 2005 | 12:45 PM
g-ride-si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOGADOGGZ &raquo;</TD></TR><TR><TD CLASS="quote">Question everyone, I have a High compression B16a Obd0 and it over heats at hard driving. What causes my head to get warped if i haven't raced or taken my car to redline at all??</TD></TR></TABLE>
If you know it overheats then i def. wouldnt be driving it hard unless you want to mess something up really bad.
Old Aug 30, 2005 | 12:49 PM
Nerologic's Avatar
Default Re: What Causes a head to get Warped????? (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">Overheating, torquing down in wrong sequence, inconsistent torque values for the headbolts are common causes. </TD></TR></TABLE>
x2
MrPscott
Jul 5, 2007 04:26 PM
jolt-tsp
May 18, 2005 09:36 AM
B18Redline
Mar 26, 2005 10:00 PM
89dxhunchback
Jan 13, 2005 01:53 PM
trbob16a
May 30, 2003 03:31 PM
