JDM B16a SMOG legal?
Old Aug 30, 2005 | 11:37 AM
andrewp1's Avatar
Default JDM B16a SMOG legal?
Well, I was looking at the jdm b16' and I know that they arent smog legal here in california. What would I have to change on the motor to make it smog legal for california emissions?Thanks for any help.
Old Aug 30, 2005 | 11:43 AM
undertheradar's Avatar
Default Re: JDM B16a SMOG legal? (andrewp1)
I have no idea but for Joshua Tree.
Old Aug 30, 2005 | 12:07 PM
hatchish's Avatar
usdm p30 ecu del sol stock intake different intake manifold or tap the stock one for pcv make sure ur throttle body mounts the map sensor its a pain basically it has 2 look like a del sol vtec under the hood oh yeah all the smog **** required on the del sol
Old Aug 30, 2005 | 12:17 PM
dantastic's Avatar
Default Re: (hatchish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchish &raquo;</TD></TR><TR><TD CLASS="quote">usdm p30 ecu del sol stock intake different intake manifold or tap the stock one for pcv make sure ur throttle body mounts the map sensor its a pain basically it has 2 look like a del sol vtec under the hood oh yeah all the smog **** required on the del sol</TD></TR></TABLE>
all this has been posted around here, heck i'm sure i've posted this information on here before.....
Just to clarify a bit: you'll need to add all the USDM smog equipment to the JDM motor. It's quite easy and can be done with commonly available parts.
This includes (for SIR-II motors going into EG's):
- USDM p30 ECU (OBD1)
- Nipple fitting tapped on the back of the manifold for the Evap Purge solenoid (NOT THE PCV as stated above, jdm motors already run PCV) OR a USDM intake manifold (USDM IT-R or Skunk2 will work also as they look almost identical to the obd1 usdm b16a unit)
- USDM b-series throttle body with the fitting for the charcoal canister.
Old Aug 30, 2005 | 12:32 PM
andrewp1's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
- USDM b-series throttle body with the fitting for the charcoal canister. </TD></TR></TABLE>
Thank you.
So when I put all of this smog stuff back onto the jdm motor is it really worth it for me to choose the jdm over the usdm engine. Like will the smog things I have to put on the jdm just make it run like a usdm b16, or will I still notice the difference between engines.? granted 10hp isnt much. but every bit counts.
Old Aug 30, 2005 | 12:41 PM
Stoich EG2's Avatar
Default Re: (andrewp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewp1 &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you.
it is said that JDM motors have SLIGHTLY higher compression ratios than USDM engines therefore the 10 extra hp. I'd say it's not worth it to live another day pollution free
Old Aug 31, 2005 | 07:35 AM
hatchish's Avatar
dantastic sorry i ment the evap but cant u use any throttle body like a d series one it would be alot cheaper dont u think?
MUGEN_EG95
Nov 8, 2009 03:17 PM
dippy
Nov 1, 2008 12:52 AM
B18Redline
10
Jan 4, 2006 04:43 PM
out_of_order
Apr 27, 2004 10:41 PM
Mentat Ghola
14
Feb 7, 2004 12:15 PM
