Slight tap feel, cant really hear it though
When i am barly on the gas but in gear i can feel a tap through the petals. It only does it in gear, but when i accelerate i dont feel lt anymore. When i did my suspension i noticed the boot from my axel riped off do u think i could be dirt or just the axel being dry from the grease getting out.
Anyway its a 2000 coupe w/ a b16 gsr trans lsd, i/e, stock clutch/axels
come on guys i know its tough but a little help.?.?.?.... Can anyone atleast tell me what the axel will do after being dry and exposed without the rubber sleeve on for a while? Could that be the tapping feeling??
i would bet its the axle, but regardless, you should have the joint re-packed with grease, and a new boot installed. You may have premature axle failure if you dont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC »</TD></TR><TR><TD CLASS="quote">I hope its the axel, can i just get a new boot n some grease... it cant be hard to do myself</TD></TR></TABLE>
axle grease is common, but if you do it yourself, you'll have to use a split boot. Its cheaper, but not as reliable. If you want the boot back like it was stock, there's a machine that has to do it.
Yea, the cv boot is probably the culprit, just by a boot kit for like 5 bucks and repack it and it should last you a a while, depending on how much damage was caused before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC »</TD></TR><TR><TD CLASS="quote">K im going to do that, hopefully the tapping will go away when i grease up the axel</TD></TR></TABLE>
if you use the split boot, make sure you check it every once in a while to make sure the grease is still there, but i bet you'll be fine.
