burning oil...but great compression...?
in the last week or 2 my d16a has started to puff. a bit at startup and remains puffing intermittantly while driving and while at idle. i did a compression test and all 4 cyl. are between 160 and 170...can anyone give me some insight on this issue and what to do about it?
maybe leaky piston rings? i have no clue, but my GSR engine is losing oil somewhere. No matter though, it's getting the "full-interanls manicure" this winter
but i am also curious
compression tests the valve seat, piston rings, and head gasket. If you are getting good numbers, then the rings are alright and the valves are seating correctly. If you are still leaking oil, its getting by the valve seals and into the cylinder when the valves open. They are very easy to change out.
nemesis25
Jan 12, 2015 04:17 PM
iBrandon
Jul 31, 2006 08:03 AM
Yosshaa
May 23, 2004 11:55 AM
Digital-R
Feb 19, 2002 08:52 PM
