how to remove the crank
Old Aug 29, 2005 | 10:33 PM
Finger Lickin' good's Avatar
Default how to remove the crank
Well, ive got this b18c1 block. Its 95% disassembled, all thats left is the crank, and the part where the oil pump is...So maybe i need to know how to remove the oil pump? But still there has to be more, considering that the crank sprocket(where the tb goes) is going to hold it all together still... Anywho with a helms that would like to help out ... experience builders
Its really fun taking this **** apart and seeing how exactly it fits together. Its one thing to talk about it and another to actually do it. yehaw.
Old Aug 29, 2005 | 11:35 PM
rjay8604's Avatar
Default Re: how to remove the crank (D-CeReaL#4)
Remove the oil pump on the front of the block and remove the rear main seal holder on the other side, then just remove the main bearing caps and you're done. But yeah you need to remove those two things first.
Old Aug 30, 2005 | 10:41 AM
Rocket's Avatar
Default Re: how to remove the crank (rjay8604)
Purchase a Helms manual. Cost alot but well worth it.
Old Aug 30, 2005 | 01:51 PM
ThatsMyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">Remove the oil pump on the front of the block and remove the rear main seal holder on the other side, then just remove the main bearing caps and you're done. But yeah you need to remove those two things first. </TD></TR></TABLE>
its pretty much common sence. putting it back together is the tricky part.. good luck also dont scratch the crank at all or dont try to pry it out, just wiggle it thats what i do..
Old Aug 30, 2005 | 07:45 PM
Default Re: how to remove the crank (ThatsMyEG)
I had it, but didnt know it. So went a pounded it some more, came right off. Thanks guys.
CRX 2.0V-T
Mar 6, 2007 12:13 PM
slowassciv33
Apr 22, 2006 05:24 AM
4LugR
May 12, 2005 04:38 AM
4drsedaneg
Jul 15, 2004 06:00 PM
NWHybrid
Jan 23, 2004 10:19 PM
