something bad happened!!
Old Aug 29, 2005 | 09:06 PM
95accordh22a's Avatar
Default something bad happened!!
alright i was driving home, in fifth gear on the highway, doin about 60 -65mph and all of a sudden the cars rpms just dropped, i tried to give it some gas and than it the rpms were fluctuating between 2 and 3k rpm. than the oil light came on and the CEL. i shut off the car and cruised to the side of the road. now the car wont start
any help would be appreciated
Old Aug 29, 2005 | 09:08 PM
prelude1897's Avatar
Default Re: something bad happened!! (95accordh22a)
Do you know what code it's throwing? That would be the best place to start
Old Aug 29, 2005 | 09:10 PM
Default Re: something bad happened!! (prelude1897)
nope cause now the CEL is off and the car wont start
Old Aug 29, 2005 | 09:23 PM
hmmm..Does anything happen at all when you turn the key? Does it try to crank over or anything?
Old Aug 29, 2005 | 09:35 PM
Ideal's Avatar
im gonna take a wildguess and say fuel pump... is it cranking? or just dead? check to see if your getting spark
Old Aug 30, 2005 | 03:41 AM
Demonlude's Avatar
Default Re: (Ideal)
Have you checked the oil level? If the light came on while the engine was still running, it could be pretty bad.
Old Aug 30, 2005 | 04:18 AM
syntax.'s Avatar
If you hear the fuel pump kick on, but youre not getting spark, then you should suspect the ignitor inside the distributor. same thing happened to me, exactly like you described.
Old Aug 30, 2005 | 07:43 AM
Default Re: (syntax420)
its cranking over, im pretty positive the fuel pump is turning on but the car is is a parking lot right now, i got to get it towed later.
and yes the oil light came on while i was driving
Old Aug 30, 2005 | 09:09 AM
tdo's Avatar
tdo
Default Re: (95accordh22a)
you should pull the CEL anyways. it will still show you what code was there. unless you reset the ecu.
Old Aug 30, 2005 | 09:21 AM
flyrod's Avatar
Default Re: (tdo)
any blown fuses? If you had the clutch in, the engine could have died, and you would get an oil light because the engine stopped turning (even if you were still moving). If the engine was still in gear and you had an oil light, that doesn't bode well. Good luck.
Old Aug 30, 2005 | 10:40 AM
Default Re: (flyrod)
alright i got the car started for some reason it started, drove it home (like 10 mins away) without giving it alot of gas. then i tried driving it again it died out again
i cleaned out the wiring going to the oil sensor and redid it (cause it was a swap so i did some wiring for it) it was working well then it did it again while driving?
Old Aug 30, 2005 | 04:29 PM
well to keep everyone updated, i took of the oil pan and found metal shavings, looks like from the bearings
XeiaieX
Jul 20, 2012 03:23 PM
whytry2002
Oct 19, 2010 08:44 PM
drew10
Jul 16, 2010 04:01 PM
elite01
Honda Civic (2001 - 2005)
20
Nov 21, 2009 04:00 PM
JDMEK206
Dec 28, 2005 10:22 AM
