91 civic w/b16a1 ecu problem
Old Aug 29, 2005 | 08:50 PM
4ghatch's Avatar
Default 91 civic w/b16a1 ecu problem
just got hookin up my motor ,tried to start it and turned the key to acsesory to here the fuel pump kick on and insted of the hum of the pump all i here is a loud buzing sound from my fuel pump relay . so i replaced it since i had an extra and it did the same so i looked to see if i was throwing a code on my ecu and all i get for that is a solid red light no flashes at all what should i look for
Old Aug 30, 2005 | 01:38 PM
4ghatch's Avatar
Default Re: 91 civic w/b16a1 ecu problem (4ghatch)
someone? anyone know what it is because my fuel pump is going but i dont hear it since the buzzing is so loud. gas comes out the fuel line to the rail so everrything was working i dont know what to look for
Old Aug 30, 2005 | 02:55 PM
turbocrx2.1's Avatar
i had this prob once before and i could not figure it out,then i went through the wire harness and found that i forgot to put the ground on that the wire harness uses to ground out (located by the water neck that holds the thermostat) so i disconnected the ecu and put the ground wire on and then plug the ecu back in and it started up .so check that ground and if connected then maybe try a diff ecu.
Old Aug 30, 2005 | 06:09 PM
4ghatch's Avatar
Default Re: 91 civic w/b16a1 ecu problem (turbocrx2.1)
thanks now it will turn over but i've got code 6 (coolent temp) i notice i have one plug left that needs to be hooked up and it under the dizzy but i dont know where it goes. There arnt any visable spots that i saw. if it helps it is a grey plug and i think its a 2 wire thanks
Old Aug 30, 2005 | 06:15 PM
drdisco69's Avatar
Well that goes to the coolant temperature sensor, of course! There should be a sensor right by the VTEC solenoid that it plugs into. The car will run without it though.
beenba
Feb 3, 2018 07:56 AM
drivingshadow
May 16, 2015 07:25 PM
96coupecivic
Jan 23, 2012 09:00 PM
JT2
Honda Civic (2001 - 2005)
Jun 23, 2009 06:37 PM
b16a1sirhb
Apr 9, 2003 11:50 PM
