Car won't start after sitting for a while.
Old Aug 29, 2005 | 08:32 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Car won't start after sitting for a while.
This just started happening. When my car sits for a while (a couple of days) and I don't drive it, I will go to start it and it just cranks but won't actually start. I can go back a little later to try to start it again and it usually starts right up. I missed class today because of this P.O.S car.
Any ideas?
Old Aug 29, 2005 | 11:00 PM
outlawstar's Avatar
Default Re: Car won't start after sitting for a while. (92prelude)
i missed work cuz of this too. but im checking my main relay tomorrow. i think thats what it is.
Old Aug 30, 2005 | 07:28 AM
kulrevon's Avatar
OK basically to start off an easy way to see if its the main relay is that you turn the key to the on position (do this when the car isnt starting) the check engine light should turn on then turn off a second later if it doesnt turn on or it doesnt turn off then its probably your main relay. also It sounds dumb but if the light stays on kick the lower dash by your left foot if the light goes off its you main relay.
the relay is located down by the left kick panel up on the wall. they say its somewhat hard to get to. I hope this works. or helps
Old Aug 30, 2005 | 08:58 AM
Community Builder
Default Re: Car won't start after sitting for a while. (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">OK basically to start off an easy way to see if its the main relay is that you turn the key to the on position (do this when the car isnt starting) the check engine light should turn on then turn off a second later if it doesnt turn on or it doesnt turn off then its probably your main relay. also It sounds dumb but if the light stays on kick the lower dash by your left foot if the light goes off its you main relay.
Awesome, I'll go try that out in a minute or two
SaveDaNoob
Jul 7, 2011 07:06 PM
black94lude
Jul 30, 2009 02:11 PM
Acidcrakker
Sep 3, 2007 08:51 PM
imoua
11
Jul 28, 2006 08:14 PM
bb6_lude
Jan 12, 2006 10:31 AM
