Suspension & Brakes Theory, alignment, spring rates....
buddy club racing spec damper adjustment
Old Aug 29, 2005 | 07:44 PM
erasable180's Avatar
Default buddy club racing spec damper adjustment
i just recently bought a 94 hatch with buddy club dampers and the previous owner gave me the directions but they arent in english. can anyone direct me to an english copy pdf or just explain how to adust them. tia
Old Oct 7, 2005 | 08:17 AM
egyolk's Avatar
Default Re: buddy club racing spec damper adjustment (erasable180)
don't you just turn that ****?
Old Oct 7, 2005 | 08:34 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erasable180 &raquo;</TD></TR><TR><TD CLASS="quote">i just recently bought a 94 hatch with buddy club dampers and the previous owner gave me the directions but they arent in english. can anyone direct me to an english copy pdf or just explain how to adust them. tia</TD></TR></TABLE>
LOL im in the same boat. i talked to robear. but havent heard anything back.
i just want it so if i sell them one day it will come with english instructions. hopefully someone here will chime in and scan them for us. or send me the instructions and ill make a pdf file for everyone.
Old Oct 7, 2005 | 03:12 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: buddy club racing spec damper adjustment (cxSHOE)
Uh...Yeah, you just turn the **** on the top. Read through the instructions, I THINK on mine there was a bit of English at the end. If not, it was in a separate book. Off the top of my head, I'm thinking that turning the shock s counterclockwise is soft, and clockwise is hard, but let me check on that before any of you go screwing too badly with it.
Old Oct 7, 2005 | 04:02 PM
cxSHOE's Avatar
Default Re: buddy club racing spec damper adjustment (sscguy)
left is soft
right is tight.
6 clicks to the left from full right (turn to the right till it stops then go back 6 clicks)is the adjustment recommended in manual....
anyone with a english installation book,,, i need a copy!!!!!!!!!!!!!!!!!!! or send it to me ill pay for shipping and make a pdf then send it back??
Old Oct 7, 2005 | 05:08 PM
Suspetise...
I'll see if I can find mine. 6 clicks from full stiff would be on about "9", and that's pretty friggin stiff. As a comparison, on the street I run at 0F/0R (full soft), and it's still pretty stiff. On track, for a dry track anyway, I've found 3F/8R to be nice. I had mine dynoed much earlier this year, and at 10 clicks there's something like 10K newtons of force, which is utterly insane. Keep that in mind when you think about using that or more than that number of clicks.
Old Oct 7, 2005 | 06:07 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">I'll see if I can find mine.6 clicks from full stiff would be on about "9", and that's pretty friggin stiff. As a comparison, on the street I run at 0F/0R (full soft), and it's still pretty stiff. On track, for a dry track anyway, I've found 3F/8R to be nice. I had mine dynoed much earlier this year, and at 10 clicks there's something like 10K newtons of force, which is utterly insane. Keep that in mind when you think about using that or more than that number of clicks.</TD></TR></TABLE>
yea if your able to scan it or something that be great, but maybe you dont have a scanner send it to me i pay for shipping, and shipping back to you?
yea not sure on the clicks. thats what the japanese manuals says is the suggested setting....
Modified by cxSHOE at 11:28 AM 10/8/2005
Old Oct 7, 2005 | 08:07 PM
Suspetise...
For the settings, you're going to have to play around with it a bit to get it to where you like it. That's the point of having all that adjustability. If you track the car, keep a record of your settings and make comments after a session about how the car felt and, if you got them, what kind of laptimes you were running. There won't ever be one setup that works the best all of the time, as so many different factors are at play, like temperature, weather, track surface, etc.
freshdaily
Suspension & Brakes
11
Nov 2, 2008 11:31 AM
turboedc2
Aug 6, 2007 05:52 AM
uNF$@#!
Sep 25, 2006 05:15 PM
Luke
Honda Motorcycles
Oct 9, 2005 02:55 PM
asubennett
Feb 7, 2005 07:34 PM
