Master Windo Switch started smoking yesterday!
i was driving and it was drizzling out. i had the window open and all of a sudden i see smoke coming from my window switch. im guessing a drop of water got in there? i try to put up the window and nothing, the driver side doesnt work but the pass side on the switch works fine. i need to roll up the window because rain is coming, how can i get the window up without the switch? thank you
i tried using a integra window switch and it plugs right up but it keeps blowing the fuse. thanks in advance
It could be that the motor fried. Worse case scenario you could cut the two wires coming off of the motor and use a drill battery to roll the window up, that is if the motor is still good.
MtbikingKing
May 5, 2006 09:27 PM
