How do you put a b17 crank in a b16 and can it be done?
Old Aug 29, 2005 | 05:03 PM
2000r#0283's Avatar
Default How do you put a b17 crank in a b16 and can it be done?
What do you have to do for this to work and what would be the results?
Old Aug 29, 2005 | 05:15 PM
SkRiBLaH's Avatar
Default Re: How do you put a b17 crank in a b16 and can it be done? (2000r#0283)
you need the b17 crank and the b17 rods.
and the corrosponding bearings.
you can use your b16 pistons.
result: 1.7L
Old Aug 29, 2005 | 05:16 PM
RMF
Guest
Posts: n/a
You take the crank and rods out of the B17 and put them in the B16.Then you have a B17 again.With a B16 block.Its the same thing .Why do it?
Old Aug 29, 2005 | 05:30 PM
sheepey's Avatar
Default Re: How do you put a b17 crank in a b16 and can it be done? (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">You take the crank and rods out of the B17 and put them in the B16.Then you have a B17 again.With a B16 block.Its the same thing .Why do it?</TD></TR></TABLE>
Correct me if im wrong but the b17 has a 82 or 83mm crank as compared to a 77mm..... Not the same thing
Old Aug 29, 2005 | 05:36 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: How do you put a b17 crank in a b16 and can it be done? (sheepey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote">
Correct me if im wrong but the b17 has a 82 or 83mm crank as compared to a 77mm..... Not the same thing </TD></TR></TABLE>
Randy is just saying both blocks are identical, and swapping a b17a crank and rods into a b16a is just gonna make a 1.7L that has b16a stamped on the block. Kind of a waste if you already have the b17a
Old Aug 29, 2005 | 05:37 PM
RMF
Guest
Posts: n/a
Default Re: How do you put a b17 crank in a b16 and can it be done? (PURPLETERROR)
Thank you
Old Aug 30, 2005 | 09:45 AM
Colt Seavers's Avatar
Maybe he doesn't have a b17 block. But if he does maybe he just want's to say he has a b16. Don't fake the funk.
Old Aug 30, 2005 | 01:03 PM
2000r#0283's Avatar
due to bills I dont have much money to stroke the b16 so I figured I would like to get a little more stroke cheaper. I have a type r crank could I use that with the b17rods or would I have to deck the block?
unified112
14
May 29, 2008 07:27 PM
Spec R_GSR
Jan 15, 2007 11:48 AM
LBDM EK97
Apr 22, 2006 03:10 PM
ridexstraight
Dec 29, 2004 10:16 PM
mr. wu
Apr 14, 2004 12:19 PM
