Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
f/s: 15x9 custom steel wheels, 4x100
Old Aug 29, 2005 | 04:47 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default f/s: 15x9 custom steel wheels, 4x100
GONE! thanks h-t
Modified by Rodney at 7:22 PM 12/5/2005
Old Aug 30, 2005 | 09:35 AM
shakedown94's Avatar
Default Re: f/s: 15x9 custom steel wheels, 4x100 (Rodney)
pm sent
Old Aug 30, 2005 | 04:43 PM
superpilun's Avatar
Hey Rodney, these look exactly like the wheels I originally bought but didn't fit because of caliper interference. I also noticed they were pretty heavy. What did you feel about the increase in unsprung weight? I feel like a light weight aluminum 15x7 would perform better in the long run than a heavy 15x9 with wider tires and a wider track width. What did you think?
Also if you don't mind me asking what wheels did you replace these with? Lightweight 15x8?
Old Aug 31, 2005 | 05:39 AM
Rodney's Avatar
Default Re: f/s: 15x9 custom steel wheels, 4x100 (superpilun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun &raquo;</TD></TR><TR><TD CLASS="quote">Hey Rodney, these look exactly like the wheels I originally bought but didn't fit because of caliper interference. </TD></TR></TABLE>
what calipers do you have? this clear the 9.4 and 10.2 brake setups. if you have a huge brake setup, they will no work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun &raquo;</TD></TR><TR><TD CLASS="quote"> I also noticed they were pretty heavy. What did you feel about the increase in unsprung weight? </TD></TR></TABLE>
to be honest, i really didn't notice it unless i was fitting them to the car. seriously.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun &raquo;</TD></TR><TR><TD CLASS="quote"> I feel like a light weight aluminum 15x7 would perform better in the long run than a heavy 15x9 with wider tires and a wider track width. What did you think?.... what wheels did you replace these with? Lightweight 15x8?</TD></TR></TABLE>
nah, 15x9 works a billion times better with a 225 kumho/hoosier. the 15x7 will work admirably with a 205, but for the larger tire, you need a larger wheel...
i had originally bought these wheels for practice wheels, as i already have a pair of lightweight aluminum 15x9's. i used them for a few local events and practice at the big events. i have since purchased another set of lightweight wheels, so i no longer need these.
Old Aug 31, 2005 | 08:19 AM
superpilun's Avatar
what lightweight aluminum 15x9's did you use?
Old Aug 31, 2005 | 06:34 PM
ottocrossteg's Avatar
what's the offset on those? Would I need spacers to make them fit on my car?
Old Aug 31, 2005 | 09:16 PM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun &raquo;</TD></TR><TR><TD CLASS="quote">what lightweight aluminum 15x9's did you use?</TD></TR></TABLE>
I think he's running Keizers. He originally had 15x8.5s, but I think he either sold them and bought 9s, or had the 8.5s widened (replace outer shell) to 9s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">(2) Custom machined Keizer 15x8.5, 3 piece billet aluminum centers, hubcentric, and does not require special lug (machined for standard tapered lugnuts) 5" backspace (+19mm offset) clears nsx/itr calipers (on itr carriers) the wheels were used on my scca autocross car, but will work on a drag car just as well. they were never driven on the street, so no bends/curbs. $500 + shipping
https://honda-tech.com/zerothread?id=1159685
Old Sep 2, 2005 | 02:51 AM
Rodney's Avatar
Default Re: f/s: 15x9 custom steel wheels, 4x100 (ottocrossteg)
jaker is correct. i use keisers. but i did go back to 4 lug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ottocrossteg &raquo;</TD></TR><TR><TD CLASS="quote">what's the offset on those? Would I need spacers to make them fit on my car? </TD></TR></TABLE>
i see you have an 00 gsr. if you hav the stock brake setup, then no you will not need spacers.
Old Oct 28, 2005 | 08:57 AM
1GreyTeg's Avatar
did you ever sell those damned things rod?
Old Oct 28, 2005 | 03:46 PM
Crx Jimmy's Avatar
Default Re: f/s: 15x9 custom steel wheels, 4x100 (1GreyTeg)
nope i think he still has em
Old Oct 29, 2005 | 12:17 PM
Lo-Buck EF's Avatar
wont fit my car. they'll probably hit my calipers
Old Oct 29, 2005 | 02:29 PM
fireant's Avatar
Default Re: (Lo-Buck EF)
I just want to compliment your jaw-dropper car Rodney. Its really nice.
Old Oct 30, 2005 | 10:36 AM
rsca_crx's Avatar
Default Re: (fireant)
pm
Old Nov 1, 2005 | 03:20 AM
Rodney's Avatar
Default Re: (rsca_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">did you ever sell those damned things rod?</TD></TR></TABLE>
no....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">I just want to compliment your jaw-dropper car Rodney. Its really nice. </TD></TR></TABLE>
yeah, it's all about the bling...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">pm </TD></TR></TABLE>
pm returned
Old Nov 1, 2005 | 01:30 PM
rsca_crx's Avatar
Default Re: (Rodney)
pm returned </TD></TR></TABLE>
back
Old Nov 10, 2005 | 08:00 AM
Rodney's Avatar
i think i am setting a world record for flakes on these wheels...
Old Nov 10, 2005 | 10:45 AM
mos's Avatar
mos
These use those 45 degree lugs right? Do dey come with the wheels?
Old Nov 10, 2005 | 11:14 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">i think i am setting a world record for flakes on these wheels... </TD></TR></TABLE>
Can you redrill them for 5lug and I'll buy them?
Old Nov 10, 2005 | 04:00 PM
HapaHaole's Avatar
Default Re: (Black R)
gotta dig the fenders.
Old Nov 10, 2005 | 09:47 PM
rsca_crx's Avatar
the "stolen cars, girlfriends, and police impound problems suck" bump.
Old Nov 10, 2005 | 11:28 PM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">These use those 45 degree lugs right? Do dey come with the wheels?</TD></TR></TABLE>
i used toyota lugnuts. they have the 45 degree taper. only thing that sucks is they are 21mm. yes, they will come with the wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HapaHaole &raquo;</TD></TR><TR><TD CLASS="quote">gotta dig the fenders.</TD></TR></TABLE>
yep, it is all about the bling
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">the "stolen cars, girlfriends, and police impound problems suck" bump.</TD></TR></TABLE>
again, sorry about your car situation bro. let me know if you still want to cut a deal.
Old Nov 11, 2005 | 04:24 PM
Mach slo's Avatar
Is rolling/pulling you fender allowed in sts/stx? If it were I would probably snag them, hopefully I could roll them and pull them enough for these to fit. Any idea if its allowed and if its possible to mod the fender enough?
Old Nov 11, 2005 | 04:33 PM
.RJ's Avatar
.RJ
Default Re: f/s: 15x9 custom steel wheels, 4x100 (Mach slo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach slo &raquo;</TD></TR><TR><TD CLASS="quote">Any idea if its allowed and if its possible to mod the fender enough?</TD></TR></TABLE>
Those wheels are too wide for STS/STX - IIRC its 7.5/8" maximum
Old Nov 11, 2005 | 08:59 PM
GBRacing's Avatar
Hey, can I buy your rear ATS Comp lites? Please....
Old Nov 12, 2005 | 12:04 AM
apexinghonda's Avatar
Default Re: (GBRacing)
Are those Diamond racing wheels? If there are then crap because I was going to get a set as "traveling" wheels for my track car. I have the 11.1 Type R brake set up and from what I am reading those wheels will not clear the calipers? Please let me know if they are Diamond.
Barry H.
