Difference between Apexi VAFC and Field SFC-VTEC controller?
Old Feb 25, 2002 | 12:54 PM
Wet Nudl's Avatar
New User
Default Difference between Apexi VAFC and Field SFC-VTEC controller?
Any comments? Thanks.
Old Feb 25, 2002 | 01:22 PM
Tommy_Gunns's Avatar
Default Re: Difference between Apexi VAFC and Field SFC-VTEC controller? (TypeRP)
In terms of VTEC controlling...the VAFC has VTEC in and VTEC out settings, where as the Field's only has a single VTEC switch over point (so VTEC in and VTEC out are set at the same point).
This is pretty handy feature. It helps you stay in VTEC while slowing down for a corner. I hate putting back into 1st when the car is moving at 4500 rpm and above in 2nd...but that's just me. More handy for AutoX as there are tighter turns.
I don't have a VAFC (but have played with them quite a bit), but if I did I'd put VTEC in at 5500 rpm and VTEC out at 4800 rpm (if that's possible).
Old Feb 25, 2002 | 01:34 PM
Wet Nudl's Avatar
New User
Default Re: Difference between Apexi VAFC and Field SFC-VTEC controller? (Tommy_Gunns)
What about the fuel controllers on both units. How do they differ?
Old Feb 25, 2002 | 01:46 PM
badCRX's Avatar
New User
On the SFC unit it was only like 8 or 10 points to adjust at. On the V-AFC yuo have 8 on the high cam and 8 on the low cam, so basically 16. You also have a partial throttle setting and a high throttle setting and you select where that dividing line is. Also there is a correction factor you can use but I never quite figured how to use that effectively.
civictypenos
Aug 25, 2003 05:29 PM
civictuned
Aug 1, 2003 04:36 PM
B18Redline
May 27, 2003 10:07 AM
98R-1144
Nov 4, 2002 05:12 PM
The Poopsmith
Aug 9, 2002 10:18 PM
