tech q's (h22a in a 97 civic)
Old Aug 29, 2005 | 12:41 PM
b.serious's Avatar
Default tech q's (h22a in a 97 civic)
i got myself an auto h22a which i plan on converting to stick shift.. transmission is a P2C4 from a 94-97 accord coupe. i did search and came with no results in particular ....
1) are the flywheels for the h22a and b16a2 the same? if not, can the b16 flywheel be used ?
2) what axles should be used in a 97 civic ex?
any help would be much appreciated.
thanks
Old Aug 29, 2005 | 12:44 PM
kulrevon's Avatar
Default Re: tech q's (acidz_z6)
the motor isnt in the car yet?
Old Aug 29, 2005 | 12:46 PM
IHateJDM's Avatar
I don't know on the axles, but i'm pretty sure it was covered in the swap FAQ thread. As far as the flywheel, B16 won't work.
Old Aug 29, 2005 | 12:57 PM
b.serious's Avatar
Default Re: tech q's (IHateJDM)
no its being put together... the tranny basically. ive gathered some information about the axles and i can have them custom made as well so lets stick to the tranny.
the reason i asked about the b16 flywheel was the fact that it bolts right up like a champ (8 bolts) but am not sure if the diameter and the depth are fine and also if the self motor would line up or not...
any dimensions on the h22a flywheel, pressure plate and the clutch??? pictures would be great....
thanks
Old Aug 29, 2005 | 01:13 PM
Rad Racing's Avatar
Bart Taylor Look-alike
You need custom axles if it's a H22 in a Civic. I can get you a set if you need them(New).
Old Aug 29, 2005 | 01:31 PM
b.serious's Avatar
Default Re: tech q's (Rad Racing)
well it'll all depend on how the motor sits in.. am not using hasports or any mount kits. am getting it done from a local fabricator whoz supposed to be veryyyyyy good with engine swaps between series... let me know the length of the axles and how much $$.. ill definately PM you once the motor is in ...
anyone who can help me with teh flywheel, pressure plate and clutch combo...
h22a here with an accord coupe tranny (P2C4)
anyoneeeee????
Old Aug 29, 2005 | 02:05 PM
Rad Racing's Avatar
350 shipped. Just use an Accord or Prelude flywheel.
Old Aug 29, 2005 | 03:00 PM
Eddiebx's Avatar
ur going to need an h22/f22 flywheel and clutch set
and the axles are all gonna depend on how the motor is sitting with the custom mounts, so i really woudlnt bother till the motor is in the car
Old Aug 30, 2005 | 08:44 AM
kulrevon's Avatar
Default Re: (Eddiebx)
I have an extra flywheel. for sale.
Old Aug 30, 2005 | 02:51 PM
b.serious's Avatar
how about using a b16 flywheel with the outer ring out of an h22......
b.serious
Sep 2, 2005 11:47 AM
H_doubledeuce_A1
Mar 30, 2004 10:05 AM
KiD-H22A
May 1, 2003 08:08 AM
redlineh22a
Mar 5, 2003 11:25 AM
