burning oil????wtf??
i have a 93 honda civic auto with a d16z6 motor with a 139,000 miles and im burning 4 quarts of oil every 2000 miles.the car does not smoke or overheat or anything like that.the plugs are clean of oil and so is the header.the car does leak oil to the bottom of the engine but not 4 quarts in 2000 miles.where is it going???if anybody knows help me out.could it be the oil i used???
Fix that leak and then come back after 2000 miles... if it burns 4 quarts in 2000 miles WITHOUT LEAKING ANYWHERE, then you have a big problem... and you shoudl DEFINITELY BE SMOKIN BAD...
But you say that there is no smoke and you have a leak so I think you rather have a leaking problem then burning problem...
If you'll still burn that much oil, taking consideration about the amount of burnt oil, I DOUBT it's the valve-seal problem... it's your rings...
But I am 99% sure that when you fix the leak, you won't be loosing that much oil...
its most likely your rings. believe me, blowby is a bitch. did the previous owner take good care of the car? if so, or if not, how did they maintain it...these things might help, only if you know the answers of course.
if the oil doesnt appear on the ground than its going somewhere else, do a leakdown test and make sure that your rings are sealing, its goin somwhere very likely its goin out the tailpipe. test first test test test.
rob_nordberg
Aug 9, 2012 08:30 PM
