Parts list... Additions/subtractions/opinions
Sleeved block w/bore
Wisco Pistons (high compression)
Balanced and re shotpeened crank
Forged rods
Jun cams and valve train
RMF header
Big bore TB
New intake Man.
AEM EMS/hondata
Ignition
OBD2 to OBD1
Flywheel
Need info on whether or not I should purchase these items also?
Fuel injectors
Fuel pump
Koyo Rad.
? on best to buy?
exhaust to go with the rmf header? (no bigger than 2.5)
intake manifold that would be best
big bore TB
Thanx for any and all info, This will def surpass my 6,000 limit but I have all winter to come up with the rest!
What kinda whp and 1/4 mile times do you think I should be getting with thses mods and good tuning?
Forged rods
RMF header
Big bore TB
New intake Man.
AEM EMS/hondata
Ignition
OBD2 to OBD1
Flywheel
Fuel injectors
Fuel pump
Koyo Rad.
? on best to buy?
big bore TB
here i will rewrite for you:
bensons sleeving
rlz spec wiseco 12:1 pistons
i beam rods
acl bearings
all arp studs
rlz head port
jg or rlz custom intake manifold
70mm throttle body
jun cams
jun valvetrain
ferrea stock size valves
8lb flywheel
stage 3 clutch
aem ems or hondata
550cc injectors
walbro fuel pump
rmf header
kteller 2.5 exhaust piping
no need for ignition
tuned by rlz
you should be able to hit 250whp....about 190lbs of torque
in a 4th gen i say you could run low low 13s, possibly into the 12s...in a 5th gen mid 13s...
i say throw in a 4.7 final drive and you will be set....
bensons sleeving
i beam rods
acl bearings
all arp studs
rlz head port
70mm throttle body
jun cams
jun valvetrain
8lb flywheel
stage 3 clutch
aem ems or hondata
550cc injectors
walbro fuel pump
rmf header
tuned by rlz
