clutch master cylinder
Old Aug 29, 2005 | 10:12 AM
714JDMBB4's Avatar
Default clutch master cylinder
my clutch went all the way down all of a sudden and gears will harley go in can this be the clutch master cylinder? how do i fix this?
Modified by 714JDMBB4 at 12:27 PM 8/29/2005
Old Aug 29, 2005 | 10:59 AM
kulrevon's Avatar
Default Re: clutch master cylinder (714JDMBB4)
check to see that you have fluid
Old Aug 29, 2005 | 11:25 AM
714JDMBB4's Avatar
Default Re: clutch master cylinder (kulrevon)
just gots an engine swap were would the fluid be at
Old Aug 29, 2005 | 12:14 PM
prelude1897's Avatar
If you going to change your master cyclinder, may as well change the slave cylinder as well. The fluid for your master cylinder is right beside where your brake fluid goes. Top corner of the driverside engine bay
Old Aug 29, 2005 | 12:45 PM
714JDMBB4's Avatar
Default Re: clutch master cylinder (prelude1897)
well im trying to see if its really my clutch master cylinder because my clutch goes all the way down and my gears are really hard to go in like if doesnt want to could it be the master cylinder
Old Aug 29, 2005 | 12:48 PM
steveobb4's Avatar
Did you bleed the air out?
Old Aug 29, 2005 | 03:19 PM
714JDMBB4's Avatar
Default Re: clutch master cylinder (steveobb4)
it happen all of a sudden from one to another the clutch pedal went soft on me it goes down easily the clutch dont want to go in. what could that be ?
Old Aug 29, 2005 | 05:34 PM
714JDMBB4's Avatar
from one day to another so havent done it
JDMswagSerf
Dec 10, 2013 09:47 PM
dgerej2
Oct 1, 2009 07:16 AM
92eg6lsvtec
May 20, 2006 05:56 AM
itsJDMyo
Oct 24, 2005 05:02 PM
aengnr1
Jun 16, 2003 12:23 PM
