What are the differences between the different manuals?...
Old Aug 29, 2005 | 09:32 AM
pbink's Avatar
Default What are the differences between the different manuals?...
Just wondering before I buy this weekend...
Is there any/much difference between the Chiltons, Haynes, Helms manuals for the Accord?
Old Aug 29, 2005 | 09:37 AM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: What are the differences between the different manuals?... (pbink)
Basically Helms is Informational-Based. More of where things are located and specifications. Very In-Depthed. Haynes is mostly Maintence-Based with "Real Photos" I've never used Chiltons. I like Helms the best. The diagrams are pretty easy to understand.
Old Aug 29, 2005 | 10:56 AM
pbink's Avatar
Default Re: What are the differences between the different manuals?... (Rad Racing)
hmm...so for instance...helms would have the specs of what the valves should be adjusted to and Haynes would have a procedure to do the actual adjusting?
Anyone else? Chiltons?
Old Aug 29, 2005 | 11:13 AM
P_Adams's Avatar
I rely on Chiltons Accord/Prelude 1996-2000 repair manual 30152.
Reasoning: I grew up using Chiltons, the independent garages I worked at used Chiltons (as did some Dealers I worked at (for the used car dept)) and I'm comfortable with it.
It includes both wiring and vacume hose diagrams which other publications don't.
Honestly, I first bought a Hayes thru Barnes & K'Nobel, took one look, and started beating the bushes for a Chiltons.
P
hellohihey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbink &raquo;</TD></TR><TR><TD CLASS="quote">hmm...so for instance...helms would have the specs of what the valves should be adjusted to and Haynes would have a procedure to do the actual adjusting?
Anyone else? Chiltons?</TD></TR></TABLE>
No, Helms will have the complete process as well, the Helms is about 4 times the size of the Haynes with that much more information
Helms is the factory manual for Honda, it is the one used by dealers
Old Aug 29, 2005 | 11:24 AM
Ghostyman's Avatar
I have a Haynes manual for my 1985 Accord and a Chilton manual for my 1991 Accord. I don't know much about cars but they've both walked me through successful replacements of alternators, a transmission, struts, radiators, etc. They both seem to have good information and fairly easy-to-follow direction.
The biggest difference seems to be that the Haynes illustration and diagrams are a lot clearer that the Chilton diagrams. The Haynes drawings are all crisp, large and easy-to-read. The Chilton drawings, on the other hand, are often small and sometimes printed so poorly as to be nearly invisible.
A similar problem occurs with the photographs. In the Chilton book, the photos are very dark and it can be very hard to locate parts. The Haynes book uses very professional-looking photos that are brightly lit and often labeled with arrows.
I think a lot of that is because the paper that the Haynes manual is printed on is much better than the Chilton book.
Hope this helps some.
Old Aug 29, 2005 | 02:09 PM
Chiovnidca's Avatar
Default Re: What are the differences between the different manuals?... (hellohihey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellohihey &raquo;</TD></TR><TR><TD CLASS="quote">
Helms is the factory manual for Honda, it is the one used by dealers</TD></TR></TABLE>
Helms is best for a Honda.
Old Aug 29, 2005 | 04:17 PM
matt_in_sd's Avatar
From what I rember Chilton has a couple of different lines of manuals. One is geared toward pros and is pretty good, the other is marketed towards guys who need a manual to change the brakes. And they suck for anything more complicated. Helms is the way to go if you plan on keeping the vehicle for a long time.
Old Aug 29, 2005 | 04:24 PM
muadib37's Avatar
Any links to download the helms, haynes, or chilton manuals in pdf/ebook format?
They are so much easier to search this way!!!
jcstites
May 23, 2010 05:04 PM
sckroege
Apr 22, 2010 09:33 AM
jimjonez
Jan 28, 2007 11:52 AM
Ryan T
Apr 10, 2005 12:20 AM
nbn22385
Nov 4, 2003 05:21 PM
