Civic Sunroof / Moonroof
Will a sunroof/moonroof taken off a 1996 Civic Coupe fit a 1994 Civic Sedan??
Please reply to pastrol@hotmail.com with any information or just post here . . .
with alot of fabrication it should work. But in Canada we had a 4 door model 92-95 called the EX-V which was a 4 door with a d16z6 and it had a sunroof/moonroof. If you really want one I would look in too getting maybe one from a 92-95 Si. Also these are power sunroofs.
That would be nice, because I have a 1994 JDM Civic Sedan and I want to add a sunroof, so if you could source one for me that would be welcomed . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGeneral »</TD></TR><TR><TD CLASS="quote">Find the cars and do the measurements. Other than that the rest is installation. </TD></TR></TABLE>
The size really shouldn't matter. If it's off of a Civic or a Mercedes, what does it matter. You still need to cut out for it, and then just wire it. Either way, it shouldn't matter what you get, it will still require about the same amount of work.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pastrol »</TD></TR><TR><TD CLASS="quote">Please Explain what you mean???</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pastrol »</TD></TR><TR><TD CLASS="quote">Will a sunroof/moonroof taken off a 1996 Civic Coupe fit a 1994 Civic Sedan??
Measure the sedan moonroof and the coupe moonroof and see if the glass measurements are the same. If they are the only thing you would have to find out is if the motor for the sunroofs are the same (I think they are).
Upon futher review you could just call the maintenance department at your local Honda dealership, don't ignore what I said before but a certified dealership should be able to tell you.
blu3g
Mar 16, 2008 08:36 PM
potator
Aug 27, 2004 04:29 PM
slthatch
May 9, 2004 06:18 PM
